M MoabChris New member Sep 24, 2011 #1 What's the best way to run the wires/harness. Watch outs/advice... Pics? Any help appreciated. Chris
M MoabChris New member Sep 25, 2011 #2 Can you use a fuse tap from the 12v accessory to power the on Piaa switch? I can't figure out which wire to tap for the switch among the ginormous bundle under the steering column...
mysticz Member Sep 26, 2011 #3 My PIAA 520's came with all the needed wiring, relay and switch to install the lights. Did your PIAA set not include the wiring?
M MoabChris New member Sep 26, 2011 #5 PIAAs Installed After a couple of trips to the part store for some bolts (for the Relay), fuse tap, and some wire protector.... here it is finished (mostly) The switch is still a hack, until I can replace it with an OEM. Attachments 1LightsOff.jpg 108.1 KB · Views: 526 1SwitchHack.jpg 131 KB · Views: 439 1PiaaOnly.jpg 89.9 KB · Views: 465 1LightsOn.jpg 100.6 KB · Views: 461
