Mounting/Wiring PIAA lights to a Westin Bull bar
Can you use a fuse tap from the 12v accessory to power the on Piaa switch?
I can't figure out which wire to tap for the switch among the ginormous bundle under the steering column...
My PIAA 520's came with all the needed wiring, relay and switch to install the lights.
Did your PIAA set not include the wiring?
PIAAs Installed
After a couple of trips to the part store for some bolts (for the Relay), fuse tap, and some wire protector.... here it is finished (mostly)
The switch is still a hack, until I can replace it with an OEM.
