MPG drop!
Bretski1
So I filled up my tank after putting on my 265/75/16 Duratracs on and I was really surprised. I had driven 237 miles when I filled up putting 16 gallons in the tank. 237/16=14.8!!!!!! Before putting on the tires I was getting ~18.75 MPG. Would the tires cause that big of a drop? I am taking into account that the circumference of the tire is a little bigger (not much) and that I've had the A/C running a little more for my pregnant wife but REALLY?
You think bad gas could cause that big of a drop? Damn you Costco! Just cleaned the MAF and TB a few hundred miles ago. Gonna try putting a little sea foam in the tank...
Ok now that you say you cleaned maf and tb, there has been a consensus amongst some, myself included, that your Mpgs drop right after that.
Some think it is the computer.
Did you reset it after?
Miller is right, even simpler you can just disconnect negative battery terminal for the same amount of time.
Will disconnecting the battery reset the radio requiring a code to be entered? This used to happen on my wife's civic and I'm wondering if that is a possibility in the T4R.
Talyn
