Multimode Transfercase Stuck in 4x4 Hi : Case study by Pine Hallow Auto Diagnostics
This guy obviously has great diagnostic skills. Something to aspire to. I did find it interesting where he chose to start his diagnostic journey though. I know it's easy to be an armchair mechanic, but after figuring out the transfer case was engaged in 4wd but the dash lights weren't verifying it was, I would have first suspected the switch on the transfer case was bad. It wouldn't go out of 4wd, because the switch was already reporting to the 4wd ECU that it was in 2wd. And, it wouldn't show it was actually in 4wd, because the switch was permanently reporting the 2wd mode.
He went down the rabbit hole of analyzing the wiring diagram for the ECU and testing all the circuits which probably ate up a significant amount of time. I guess what I'm trying to say is with any diagnostics, it's a benefit to know what would be the most likely culprit for the problem at hand and test that first.
I diagnosed a similar issue on a GX470 for anyone that's interested in watching it.
I figure I'll resurrect this thread because it may help someone else.
2002 SR5 with push button on 4WD control lever and center diff lock switch on dash (left of steering wheel).
I had the continuous flashing 4WD/center diff lock light and vehicle wouldn't come out of 4WD.
Finally got underneath and removed the two switches (sensors) on the actuator. The one closest to t-case was NFG. I hope this was the only problem. The vent/vacuum line was a little crusty, so that got cut back to good tubing and reconnected.
New amazon special switch (84222-12010) due tomorrow. Will update tomorrow.
Great job! How did you go about removing the switches? I have heard some people able to get them out with crows foot wrenches and others have lowered the transmission slightly.
I managed to get a 1 1/6" full size wrench in above the driveshaft. They weren't that tight and was able to break them and unscrew by hand. I sprayed them first with Brake Clean, wire brush and then some Kroil.
Same thing for tightening. hand tighten and then maybe a flat or two with the wrench.
delislerebecca
