My 98 Limited
Nice bro! I've been wanting to upgrade brakes like this for a while, just gotta test my rim/tire setup on my friends Tundra first make sure it all clears. Keep it up!
Mahalos Bradda B. I usually write up when I'm done, but just get chicken skin reading everybody's post. Wanted to lift da front da same x as doing da brakes, but neva have x fo get all da parts. Bumbai next week should have all da parts fo lift'm up. I really love my MTRs, but money's tight and gotta use wat I have. My 285 Toyo A/Ts work fo now. Fo shua getting da MTRs when get bolo head. Aurite! Mahalos and Aloha.
Yesterday was the 1st time I broke in my brakes and after I did the 60-45 6x, then 60-10 6x. All was very good. Reason for doing the Tundra brake upgrade was because my 98 rotors we're doing the shaky when applying. No more shaky now!
So I drop off my son to school and went to the Junkyard. I got something from a 01 taco. I didn't want to modify Alot to make it work, so most work was done to the shifter console and 2 side skirts to make it presentable. The 2 bolts that connected to the rear console matches, but had to be smoothed out for the back console to be fitted over. Also the back console has a L lip on both sides, so I made a slide with my cutting wheel. I also had to cut both front and rear of the shifter console to clear the wires and abs box in the front. Finished it off with cutting the 2 side skirts to fit. The color of the shifter console is GREY,but for $5 & it works. Took me 2 total he's for the install. Now I'm on the lookout for a tan/oak console and make it happen. Enjoy the pictures.
Scored free OME N91S/ OME coil? Well I got this set free from my friend as he has a 06 TRD Tundra. He's got the coilovers in his and had this set layin around. He got this lift at ARB & used it for 2 months and popped a CV, then decided to take it off.
I took the Tophat off and the shocks were dead. So I have to buy new shocks. I'm going to buy Bilstein 5100 Tundra front shocks.
I measured the shocks and It measured 15 1/4. Because I don't know what coil this is, the only measurement that comes close is the 882 witch measures 15.55". Don't know what the 883 measures. The coils I counted was 10.75 wraps
OME 2880 500 .630 14.37 4Run/Tacoma
OME 2881 500 .630 14.76 4Run/Tacoma
OME 2882 500 .630 15.55 4Run/Tacoma
OME 2883 Prado
Above is some info from OME
Here are the springs assembled
Just springs
Dead shocks N91S
These were in the middle of the Tophat and spring
This is the free height of the spring, 15.25"
I was just looking on Toytecs site today at their OME coil setup (no shocks). Glad you've already been through this so I have someone to reference to when I get my lift.
You didn't get a diff drop or anything else, did you?
All I got is the rear adjustable panhard bar from toytec. Other parts I have are front LC coils for rear and rear LC shocks for the rear
Picked up some LX450 front springs for my 4runner today.
19.5" Purple Green White 8 wraps
19.25" Double Purple Dark Blue White 8 wraps
Waiting for parts just kills me. I want to lift my truck badly, but have to have patience for my parts to come in. I ordered the adjustable rear panhard bar from ToyTec and just waiting for my friend to get my front struts from OME.
Sorry, just needed to vent for a moment. I was just going to buy the Tundra 5100 Bilstein, but read they feel like $hi+ for the ride. Anybody that had this combo confirm this? Well all you T4R owners have a good day.
So I've been out of service and trying to do small things and this is what I've been tinkering with. Put my lift on hold because I'm doing this first. All parts are Genuine Toyota except the grille. I hate trying to make it fit, (OCD) some parts of the grille doesn't fit smoothly. I might end up getting a Genuine grille as well. It's not on the truck yet, (doctors orders) but it's will. I painted the hood with spray can cuz I wanted to see just because. Kinds good because, by the time I recover the pieces will be done from the paint shop
So I did the Tacoma Conversion 2 nights ago and did have to modify some small things to make it work. Everything else bolted up.
The hardest parts was 2 things:
1st was taking off the core support. Not only do you have to take the spot welds, but you also have to pry apart the glue that bonds the metal together.
2nd was adapting the 4runner Limited flares to the Tacoma fenders. The Tacoma fenders have a higher arch than the 4runner. I used the 4runner wheel well plastics.
The things that had to be modified:
Under the front L wheel well is a canister that has 2 bolts holding it to the wheel well and the core support. The bolt that is bolted to the core support is longer than the hold that is already there. So I just drilled and put a nut and bolt to HD in place.
Another thing that had to just relocate was the L horn. The 4runner core support comes with a nut welded to the support. The Tacoma doesn't. There is a hole by where the 4runner support is, so I just put a nut on the other side and tighten it. I also used the 04 Tacoma horns. The 4runner horns were wimpy and the Tacoma ones have the actual horn looking horns. They also have a better sound.
I always like the look of the Tacoma front and I am glad I got the chance to do it.
There is one last thing I'm fussing with, the brackets that hold the tail of the bumper and the side front of the fenders.
The Tacoma brackets hold the fenders perfectly but are to short to hold the bumper.
The 4runner brackets are perfect for the bumper,but the hole for the Tacoma fenders is lower.
So my final decision is going with the 4runner brackets, but I will have to drill a hole in it to hold the side front of the fenders.
seltzernator
