My 98 Limited
FOOTWELL WATER TANK - BY FRONT RUNNER
This came in yesterday afternoon. Here's the info:
This cleverly designed 40l (10.6gal) tank is extremely strong and is shaped to sit on the vehicle's floor behind the front seats.
Made from food grade polyethylene and is BPA free.
The cutout spans the transmission tunnel and the top section can be used as a nonslip floor or stacking supplies/luggage on top of.
This design allows for fitment into most vehicles.* Please check specs to confirm correct fitment before purchase.
If children are to be seated in the rear, the tank can be strapped to the front seat mounts using normal ratchet tie down straps.
The tank has plastic pipe fittings on each side for connection of a hose and tap. (Hose kits and taps are not included)
The Water Tank Hose Kit - by Front Runner are sold seperately.
SPECS:
Material used:
Tank: BPA-free polyethylene
Fittings: Plastic
Capacity:
40l (10.6gal)
Product Dimensions:
W 1200mm (47.2") x H 180mm (7.1") x L 250mm (9.8")
Cut-out:
W 210mm (8.3") - W 300mm (11.8") x H 110mm (4.3")
Weight:
4.98kg (11lbs)
I'm making my own hose kit as I'm putting quick connections to make it easier and will also installing a 12V pump inline when using it for camping.
If I missed it, sorry... But did you ever get your 12V pump installed for your tank? I have one now and ended up making my own hoses as well. I like my setup, but having a pump will open up some good possibilities to use it.
No I have not gotten a pump yet because my Kariba Shower system has a pump that pumps the water out of the tank
I installed this ROCKFORD FOSGATE Power 200.1 to power my JL AUDIO W3V3 6.5” Subwoofer
Here’s what I did and where it sits. I like how small the enclosure is and its not bulky. This sub hits hard for its size
How my fridge sits as of now. In the process of building a slide and barrier for the fridge
I also took a picture of my drawer loaded and open at full length
Well I went to Canada for the weekend before flying back home to Hawaii last month. Long story short, Canada has a lot of dips in the road and I Wuz bottoming out. I get to the destination and look under my truck. I only had an inch of travel. Well it’s been a month and I’m not traveling, so what better way to change my LX450 springs and change to the OME861. It went higher and the spring caries the weight nicer than the Cruiser springs. Im still running the OME shocks and will be changing them out soon
So I just did this. Seats are from a 04 Tacoma X-cab. Seats r 60/40 split seats Tan in color.
Mods I did were both outer rails (passenger R and driver L rail front and back feet) were drilled out and replaced with 4runner foots.
I relocated the rear heater switch to the front console by the bottom of the shifter. I really like where it is because I would always have to reach in the back to turn it on for my son.
Why go with the bench seat? Never seen anyone swap IN a bench....everyone wants buckets with a center console/armrest.
Wanna sell me your rear cupholder?
Because my lil one wanted to sit next to me on the trails. Besides id rather have my arm around my son than putting my elbow on the armrest. I also can fit 6 people in my truck now. Before I had my drawer system I had a 2 seat bench in the cargo area which I could seat 7 people in my truck.
Negative on the rear cup holder because I’m still using it.
Besides I still have an armrest when my son is not sitting next to me
