My Dasaita Headunit Experience/Tips
Hi there
What year is the 4runner?
I have a 2013 that came with the OEM CD player and non JBL speakers
I just put a G12 in it and there was no canbus module in the harness dasaita provided (there were canbus modules for the other radio versions for 2014 onwards)
It installed ok, but the "party mode" amp does not work any more, nor do steering wheel controls - it seems like those plugs were missing from the wiring harness Dasaita provided.
Was this an issue for you?
Had shared this over on Reddit but thought it'd be worth sharing here as well. Since I've had my 4Runner I've been searching and have seen a lot of people asking about the Dasaita headunit and figured I'd throw in my $0.02 since I haven't seen too many people use the stock GPS antenna and I haven't seen anyone use the XM
Antenna.
Have had my Dasaita Headunit for a bit over a month now, overall, I like it, but it's definitely not perfect. At full price I think I'd be a bit disappointed, but got it as an Amazon warehouse deal for $464 and overall does what I want, better screen and Android Auto. Paired it with TWO of this kit from crutchfield/Amazon and this adapter to utilize the stock GPS antenna as well as the stock XM antenna for WiFi paired with this adapter. The use of the XM antenna for WiFi isn't needed but I figured if it's there, I might as well use it. Fortunately Toyota went a bit wide on the frequency range since technically WiFi shouldn't work on an XM antenna, but it's been great for me so far, little bit better range than the tiny stock antenna that comes with the head unit, I'd imagine mostly due to location for reception.
Install was super simple, followed this video and was able to just take my sweet time and do a clean job. The trim was a better match than I was expecting, it does look pretty OEM.
My biggest complaint is the screen is pretty bright even at the lowest setting, took some getting used to for night driving, but not a huge deal to me and there are some work arounds if you don't mind playing around. I ended up adjusting the settings within the headunit's factory settings (code 126 to access) and then utilized this app to get it even dimmer. I ended up installing a different launcher to adjust the look.
The wireless Android Auto is hit or miss, I personally just use wired since my phone just sits in my dock anyways.
Having Google Maps without a phone is nice, although the layout is a bit weird given the wide screen. But great in a pinch. I rarely have had to use that though since I tend to always have my phone on me.
One thing to note if you plan on using wifi/bluetooth a lot, it seems that since it only has the single antenna you can really only use one at a time effectively. If you try to use both at the same time it can be a bit spotty, it can work, but it can be a bit more hit/miss. This was true with the stock antenna and the car's XM antenna.
The steering wheel controls are great, and honestly, that alone was worth the upgrade to me, being able to move to the next track and pause/mute was more intuitive.
The knobs aren't as nice as the ones on the OE unit, they're just hard plastic but I never use the knobs, I use the steering wheel controls so that hasn't bothered me, but definitely worth noting.
Since I didn't use the kit's GPS and I didn't install a front camera, the cabling was actually pretty minimal which was nice.
I however did opt to utilize all the USB ports and HDMI port. I had the blank spots in the glove box since my stock USB and 12v are on the center stack. Decided to populate those to better utilize the ports the Dasaita unit offers. Have this USB port in the 12v slot and this USB/HDMI adapter in the smaller blank button next to it.
For what it is, it's a pretty nice kit. It's not the fanciest most high-tech kit out there. But I definitely consider it an upgrade over the stock unit.
If you're interested in anything in particular, let me know, happy to answer any questions / share and pics/vids you may want. Still learning so might not have all the answers, haha
I used this for my 2011 4Runner SR5 aftermarket head unit to retain steering wheel, handsfree functionality, and optional NAV data input. It comes with an OBD-2 V3 2-pin connector with simple straight forward instructions.
PAC RP4.2-TY11 Wiring Interface
PAC RP4.2-TY11 Wiring Interface Connect a new car stereo and retain factory JBL system, steering wheel controls, and aux input in select 2005-19 Toyota, Lexus, and Scion vehicles at Crutchfield
RP4.2-TY11 Owners Manual
https://images.crutchfieldonline.com/ImageBank/v20230323160700/Manuals/541/541RP4TY11.PDF
Metra AX-TOYUSB-2 USB Port Cable (to utilize the USB in the glove box)
Metra AX-TOYUSB-2 USB Port Cable Allows you to connect the factory USB port on select 2010-up Toyota vehicles to a new car stereo at Crutchfield
Everything works like factory. You can also buy a direct replacement mic with an 1/8th" jack that works better than the stock one.
Enfig MIC-TOY1 – Toyota and Lexus Factory Fit Custom Microphone
Enfig MIC-TOY1 – Toyota and Lexus Factory Fit Custom Microphone – Enfig Car Stereo
Don't even get me started on the Party Mode rabbit hole you'll go down with this truck.
Cheers!
I know this is an old thread but I just got. G13 and can't figure out Party Mode
AndiGarage
