My TRD Pro Lift
Here is my Cement Pro. 2/1.5 Cornfed and just slapped some 285 Ridge Grapplers
Looks great! Sale still on!
5th gen lifts, On Sale - for sr5, trd pro, 3/2 w/uca's etc. at Burtman Industries
Spidertrax wheel spacers at Burtman Industries
Jason’s 1.5/1” spacers with 285’s. No clearance or rubbing issues under slight to moderate articulation. Need to push it to a near max posture and check. I have had these spacers on for 20 months now without issue. The reason I have the 1.5/1” kit is that I had 275’s prior. 2/1.5” is the perfect place to start for 285’s, but, so far, so good. Pics show under slight/moderate articulation.
I have a 2020 TRDP, and I'm about to install a C4 rear bumper with a single swing arm. will eventually install their slimline front bumper with a winch as well. Any suggestions on which spacers would benefit me the most. I'm a little worried the extra weight will cause the suspension to sag and not interested in upgrading the suspension anytime soon.
Great pics, thank you! Sale still on!
Just finished installation of 1.5/1 spacers from Burtman. I just wanted my 4R to look a little more "proper" lol.
Not going for huge tires or anything as I already have a built FJ Cruiser on 35s for the crazy stuff.
Stock:
1.5"/1":
Well I was going for a mild lift while retaining the stock TRDP Fox shocks and I got the look I was aiming for but the ride is a little too bumpy for my taste. Not for me. I'm going to remove these spacers.
I have a 2019 TRD PRO with front leveling spacers only. I was curios if anyone was running the same setup. I want to get some tires that fill the wheel gap a little bit more and was looking for some pictures of what is out there and working without having to make any other modification.
Is it me, or the picture angle, but it looks like they gave you a little rear end sag now as well?
Stock:
1.5"/1":
275’s on a completely stock Pro. No rubbing or any issues.
1.5"/1":
Looks great. And anyone worrying about clearing with 285's, no issue, just go with the one of the larger kits I sell. Many choices all the way up to 3"
What bumper is that?
Sent from my SM-G975U using Tapatalk
Theoretically speaking. 275/70/17 is 6mm closer to the suspension components while 285/70/17 is 10mm closer to the suspension components.
I just don't want to buy tires and then be stuck with issues.
If you have a Pro with the factory Pro wheels you should have no problems. The fender liner is cut at the port on the Pros and the wheel offset and 7” width on the Pro help eliminate the clearance issues
So do you think that the 285s will fit with the front leveling kit only? Have you had any experience with that setup?
I have a 1.5/1” Burtman spacer lift and clear 285’s.
Anyone have anymore pictures of the custom 2.25/2 spacer lift? Or even the 2.5/2?
I'm tempted to pull the trigger on a spacer lift this weekend if I can find any Black Friday / Cyber Monday deals.
Laredotx
