Need help/part number for hard lines on 1st gen v6
crash813
Could use some help. Trying to find the part number for the mess of vacuum and coolant hardlines that sit under the intake manifold of the 1st gen v6. It seems that one of the vacuum lines got destroy under the intake at some point in its life as well as the coolant line rotting away.
Trying to figure out if its best to block off the broken line, rig up a fix, or buy the whole mess of lines.
a few images:
WP_20130913_015_zps25778e7e.jpg~original
WP_20130913_016_zpsa21ffac1.jpg~original
This may seem crazy, but I bet a Toyota dealer could tell you the part numbers and availability if you check at the parts desk.
Well, half the time I call the dealer, they don't have a clue what I'm talking about and suggest I just come down there and look at the pictures. Truck is apart so no driving right now. Thought it might be a little more common knowledge out there since I've seen some of the newer gen recommend replacing the coolant line but those seem to be seperate and not all attached like this one. I've tracked down the damaged line and have decided to just run a separate line.
toydiy.com
toyodiy.com is great resource for part numbers.. This one is for a 2nd gen V6
part number:tube assembly 17360-65050
part # 17360-65010 air tube assy 11-87 to 8-88
part #17360-65021 air tube assy 8-88 to 3-89
here are your part #`s speacial order though the 65010 is no longer available and the other # as far as toyota is concerned there are only 11 left in the whole wide world so you better get it ordered fast
