Need help tapping into a good remote wife for amp.
bbenson
Need help tapping into a good remote wire for amp.
I have my amp under my drivers seat and need a good wire to tap into acc for the (remote) amp wire. Anyone know if there is a good one to tap into under drivers seat or behind the radio? I can't seem to find the radio wiring diagram for 2016 non jbl entune.
Come on, need help to finish amp install. Any one have a good wire to tap?
It gets tricky. The best way is to use a multimeter to test ignition-on fuses in the miniblock under the dash there. I used an add-a-circuit from the auto parts store and it works great.
I heard Ashley Madison is good for 'remote wives' ����
No, it was discovered that AM was really no good for that. Just a scam.
Tap into [MENTION=47340]Titanpat57[/MENTION] 's wife. Everybody else does. :)
:fencing: Shots fired!
Mini tap on p-outlet fuse drivers footwell fuse panel.
This method works. I know there are at least a few open slots that have key-on power. Or you could try one of the following;
Ignition 12 volts BLUE (+) DRIVER KICK PANEL WHITE 48 PIN CONN, PIN 7
Ignition #2 VIOLET (+) REAR OF UNDER DASH FUSE BOX WHITE 56 PIN CONN, PIN 52
Accessory RED (+) REAR OF UNDER DASH FUSE BOX WHITE 56 PIN CONN, PIN 48
I've searched for what wire on the radio, but can't seem to find it.
Sounds like your hunting for a certain part of the female anatomy. Sorry not sorry the language used throughout this whole thread is ridiculous. :rofl:
Came here to make a joke, appears as though they have all been made already. As stated earlier easiest way is to whip out the multimeter and start testing fuses to see which one gets juice when the ignition is turned on.
Thanks for the help. I had a wire come off the amp while trying to get the remote wire figured out and it threw me for a loop. All set now!!!
