New Lockpick 2 from Coastaltech
AE1M
Member
This company has a new product that is for my 2008 4R Limited. I have factory Nav system. What features does this actually add? (taking delivery of the 2008 early next week).
Does it allow use of NAV while moving and playing of DVDs on the screen? Do you lose any existing features/functionality?
Bob
http://www.coastaletech.com/lockpick2.htm
Bob
Getting answer from them via email has been difficult
Hello,
i'm interested in your LockPick2 for my 2006 4runner with navi/back up camera. I'm wondering if you had pictures of your product that I could see and perhaps some instructions so I know how extensive the modifications will be. I look forward to hearing from you.
Best Regards,
And their response
Hello,
It will be a plug and play installation. No wires are cut, spliced, sodered, or damaged. This will install into the back of the radio. Therefore it will requie some of the dashboard to be disasemmbled in order to acess the back of the radio.
Notice certain questions have been avoided. I haven't really pursued it further. Supposably they are better over the phone as I've heard on other forums. I'm still wondering about a full list of new features gained.
They seem to lump together navigation, and then navigation with DVD and reverse camera. I have navi with OE reverse camera. So how does it work then? I'd like to know all the details before spending this much money on some wires.
http://www.autosoundcentral.com/LockPick_2WF_Toyota_Nav_DVD_UnBlock_Lock_Pick_2_Ne_p/lockpick2wf.htm
It won't allow you to play DVDs. It'll allow you to play videos from your iPod to the nav screen ($229 model). It offers a permanent bypass to the lockout of inputting addresses, making calls, etc. when the 4Runner is in motion. Also, let's you use the backup camera outside of reverse.
Don't mean to rain on your parade about CoastalTech. Are they actually shipping the products? They've seemed to hit a snag with production issues for the longest time. The last I've heard and checked, they haven't shipped anything for over six months. Hopefully that's a thing of the past. I was looking for lockpick about a year ago.
How would it allow playing video from iPod? Where's a video input?
I received my lock pick 2 last month. The instructions that it comes with aren't very good. I had to take my nav unit out several times before getting it to work right. Their e-mail response is almost non-existent, but if you call them, they are very helpful. Not sure about the iPod video or playing DVD's, but all functions work with the vehicle in motion (press the power button twice to activate and twice to de-activate). Also, once the unit is activated and then deactivated, it takes about 15 seconds for it to reposition itself to the right location. Not a big deal to me... Hope that helps.
Thanks for the reply. Can you document the problems you had for members (including me...!) who purchase it and will install?
Not sure about your activate/deactivate it comment. Once installed, I just assumed all functions are available all the time. Do you need to take some special action every time you want to use the Nav system while moving?
Is this writeup on head removal accurate?
http://www.castulucci.com/projects/carpc/oemnaviaccess/
Bob
The main problem I had was the instructions. The instructions show 2 basic designs of the Toyota Nav. The instructions state to connect the wire shown on the photo of the instructions. That didn't work for me. I had to connect almost all the cables including the pass thru cables. There are 3 wires that were not necessary (2 green connectors and 1 black wire with a red crip on the connector). When the green connectors were connected to the NAV, the GPS part of the nav no longer worked. I verified this through the service menu and found that the GPS was not receiving a signal. As soon as I disconnected the green connectors and replaced it with the factory wire, it worked fine. Of course this meant taking the dash apart several times (each time I found a problem).
The lock pick 2 is not active all the time. You need to press the power button twice to activate it. Twice again to de-activate it. When you activate it, the GPS stops tracking. You can input addresses, phone or whatever while the vehicle is in motion. When you de-activate it, the map will start tracking you from the time you activated the lock pick, it will not show your true position for about 15 seconds (GPS needs about 15 seconds to lock on).
Press the info and power button twice and the back up camera will come on in any gear.
The website showing the removal is pretty good, but I added some notes for you.
Photo #2 - I didn't need a screwdriver, just pulled straight up (your center console lid needs to be open). I also used the ashtray cover to pull straight up. Mine came up pretty easy.
Step #2 - There should be 2 screws holding down the rest of the console (on either side of the shifter.
Step #3 - I would do this first...
Step #4 - Don't forget about this screw (first photo).
I didn't have to remove the plastic center console storage cubby cover.
If you use a socket, you can still get to the screw shown on photo 4 of Step 4.
Removal of the temp. control unit, just pull straight out from the bottom, just enough so you can grab the sides. You want to pull the unit straight out, do not try and pry it up or you may break the tabs off.
The rest of it is pretty accurate. Getting the main console (air vents, hazard button, rear window button) is a little tricky. You just have to wiggle it around until it comes out.
I also used a heavy towel over the cup holder/shifters so when you pull the nav out, you can rest it on it without damage to the screen.
The unit of his nav is slightly different from mine, I have a 2007, I think it's a E7008...
Hope this helps.
Good luck...
It plays the iPod video through the iPod cable. There's no video cable. I have something like this for my lexus. It's great watching movies on long trips.
Hope this helps.
Good luck...
Hi, I did the Lockpick install this weekend and it went fine, I did leave the green connectors unconnected as you reported. My unit now works in all modes while driving and a DVD option now is available for video with the extra inputs provided.
Hi, I'm glad that your system works. It took me several tries and taking the interior apart many times (I can take the nav out within 10 minute now). I think the green connector has something to do with the nav's antenna. Without the green connector connected, there was no satellite signal (verified through the service menu).
When I contacted Brett (several times), he was helpful. I suppose because I had a problem and they didn't want me to return it...
Glad everything worked out for you in the end.
This is very odd. You originally said you needed to leave the green connectors DISCONNECTED for the nav system to work. I left the green connectors DISCONNECTED and everything works fine.
from your earlier post:
Bob
Sorry... What I meant to say was that I had to leave the original connector in place and not use the green ones. The original connector I believe is related to the GPS antenna. Sorry for the confusion...
Tx470
