New oem tire problems
cv470
Need help guys just replace the original Yokohama tires on my 2010 4runner limited with OEm Bridgestone from the dealer same size as the original tires but now when I turn turn left or right I get this awe full sound like the tire are hitting or rubbing on something i have gotten out of the truck to check but don't see anything!its a loud thump sound.
HELP
I would take it back. If the tires are the same size you should have no issues (unless they have some type of huge shoulder). Hopefully they can look it over and make sure everything was tightened down properly and the tires are in fact the size they stated.
OEM tire problem
I live on a hill when I drive down the hill and stop at the bottom of the hill at the stop sign I also hear the thump sound like something is snapping from the tire area
Oem tires
Got my appointment for Friday that's the only day I can get back out there mean time I won't be doing much driving once
Thanks guys can always count on you
PLEASE take out the lug wrench next to the factory jack and make sure the lug nuts are tight, at least.
Very dangerous for you and others driving around with loose wheels- even if it's just around the corner.
^ 1 BILLION!!! HELLO!!!! Right is tight, left is loose.....
Keep the appointment to make sure the studs aren't damaged. But this is something that anyone with a driver's license should be able to do.
Oem tire problem
Well guys took her to Toyota to check out the noise they removed the tires check suspension and nothing went out to test drive with manager and nothing get home and there it is when I turn the wheel I hear the clunk but not all the time what can it brim lost help guys
it could be a number of things maybe your four drive lever is not engaged all the way but a clunking noise is never good make sure you didn't run over a stick and jam something up underneath sometimes the spare works loose I can't believe Toyota can't find anything go to another dealer something like that would drive me nuts they should be able to find it
DionicioLives
