Got these 2018 rims and some Falken tires going to install and new tie rods tomorrow. Also bought bushing steering rack bushing kit. May also repack bearings, anything else I should pay attention or attend to while I’m in there ?
Agreed. It wasn't hard to remove the OEM bushings on both an old (original) and new rack to put poly in place. The rubber is soft enough that they can be pushed/pried out by hand, basically.I guess I dont know what bushings your talking about..as the mounting bushings are an easy replace...no burning needed. Replaced mine with poly and took out a lot of vibration and slop.
If your talking internal and seals...well thats a big chore and yes I think the rack has to come out for that.
Can you clarify ?
-Charlie
My bad. I just went outside and took a look at the rack I just took out. I assumed those 2 rubber bushings that the bolts go through were the metal-ringed pressed in style bushings...like in a traditional control arm. Those 2 are only simple rubber bushings that seemed they would push out pretty easily. You would still have to take the rack out of teh truck to replace them though.
Agreed, no burning, no OTRE/ITRE removal, no rack removal needed for the bushing replacement, ask me how i know. The rack just gets moved back a bit after you remove the 2 rag joint bolts and rack mounting hardware, its wise to mark the rack and lock the steering so goes back on the exact same spot.
I just did this a few days ago. I undid the bolts holding the rack and also had the tie rods lose cause I was replacing lower controll arm bushings. Likely only need to remove the drivers side if any.
