newbie question about tire pressure
lordhowe
I have a set of 33x12.50 bfg mud terrains riding on 15 x 8" rims. i was wondering what pressure i should be running them while on road. and what's a good rule of thumb for off road pressure.
right now i have been running them at 40 PSI on road and half that in sand. I don't want to wait till noticeable tire ware before i changing the pressure.
thanks!
40 PSI is waay too high.
Look for a sticker on the door jamb that gives you the tire pressure, or in the owners manual.
And in the sand I'd go down around 12 PSI or so.
Of course I wouldn't take my truck in the sand at all.
i know the stock recommended tire pressured based on stock tires, but i'm running 33x1250's and wasn't sure what the correct on-road pressure for that tire size....
Steve8v92 said:
The correct psi anywhere from 29-32 I run mine at 31 lbs.
Same tire.
Would never run a tire at 40 lbs, hahaha
31 PSI? wow that's pretty low from all of the research i have found.... how is your tire wear?
I would agree with above stated.
Street I ran 28 on the street with my (33x12.5) Swampers on my 82 truck... and running 30 on my 4Runner.
Trail On the trail, I was running 10 in front, and 8 in rear on the pick up.
4Runner, 12 fr/rr.
Chalk Test..I'd recommend doing something similar for your application. Each vehicle's mass, and the loading characteristics of the name brand/model of tire will vary to some degree.
Draw a line of chalk across the tread. Drive around the block to see how much contact patch is actually in use at a given pressure. 85%+ of the chalk should wear off while driving if your using correct pressure.
Hope this helps...
