No longer able to initialize the rear hatch window. What the heck did I break?
shine
Member
Was wiring up a mod to pop the rear hatch and lock/unlock and roll up and down the rear window today. At some point I was able to do all of that using the new wires that I connected. But then I got myself into a state where I don’t seem to be able to initialize the rear window anymore.
Here’s what works:
• Roll the rear window up and down by pressing and holding the button on the dash
• Lock and unlock the 4Runner using the key on the hatch or the driver’s door
• Open and close the hatch normally
Here’s what doesn’t work:
• Auto-up and auto-down no longer works on the rear window
• Rear window wiper doesn’t wipe
• Rear window defroster doesn’t come on when I push that button
• Cannot lower or raise the rear window using the key on the rear hatch
• Window down button on the remote causes the car to beep, but window does not go down
Things I’ve tried:
• Disconnect the negative terminal on the battery for an hour or so, then reconnect
• Pull the ECU-B fuse for about 10 seconds or more, replace it and lock & unlock using the driver power door lock switch
• Using the switch on the dash, fully lowering the rear window, keep pushing the window down button for a couple of seconds, the fully bringing it back up again and keep pushing the window up button for a couple of seconds after the window is closed. All with the ignition in the On position
• Verified the doors are closed and the power window lock-out button is not pressed
• Tested the wiring I added, one of them pops the latch when grounded, another one locks the car and the third unlocks it. I disconnected the wires for good measure to make sure they were not causing problems.
• Inspected existing wiring in the hatch, nothing looks out of the ordinary
• Searched this forum… (:
At one point in the process I was able to lower and raise the window using the wiring that I added, but noticed that my wiring was preventing the window from fully lowering. So I raised the window and secured the wiring so that it would no longer interfere. I believe it is after this that I am no longer able to initialize the rear window.
Any ideas what I broke?
Which tutorial are you following for the back window roll up mod?
https://www.youtube.com/watch?v=C7RNtceSyQI
The mod I'm doing is different from the one in the youtube link above.
Not following a tutorial, just building on this wiring diagram. The rear key lock on the hatch ("Tailgate Control SW" on the diagram below) isn't really a lock but just a switch that closes a circuit between ground from pin 19 to either pin 4 or pin 5 on the back door ECU.
Pin 19 just provides ground, so you can just connect pins 4 or 5 to any ground on the vehicle.
To follow-up, replaced the Back Door Rear Gate Window Motor and the Tailgate Power Window Regulator - still not able to initialize the rear window. I suppose that leaves just the ECU and the wiring harness next.
Update: replaced the back door ECU, now I'm able to initialize the rear window and everything works. Rear window goes up and down very smoothly and quietly with the new window motor and regulator.
My mod works too.
