No Rinse - Thanks
1engineer
Moderator
As most of you know I try to help out here from time to time, usually with explanations of "why" things work as they do and simple concepts. Sometimes though I see a post and... well, I digress. This time though I just wanted to say thanks!
While My 4Runner is mostly stock I work hard at keeping it clean, as I have done with every vehicle I have owned since I started driving 34 years ago. I have always used the simple bucket, rag, hose and car soap method. Thanks to this board my old method will be the exception instead of the norm. Based on posts from many of you who already used this No Rinse brand of car wash I decided to try it. I have a BLACK 2011 SR5 and as everyone knows black is unforgiving when it comes to being clean and it shows many scratches. With that in mind and with some trepidation I ordered No Rinse from Amazon for around $15.00 back in January. The first wash was a beautiful day in January with the temperature right at 32 degrees. I bought a square bucket with two compartments that hold one gallon each. I filled both up with one gallon of hot water (not too hot as hot water on cold glass sometimes has undesirable results) and put one ounce of No Rinse in one compartment and left the other side clear. My method was to spray the tires first with armor all tire clean foam and I washed the wheels last so I would not get the tire shine on the paint. I followed directions and washed one panel with the no rinse rag, followed it up with the clear water and then dried the panel. It took me 45 minutes the first time. Now it takes about 30 minutes and the results are great! Now every time I wash it takes: One ounce of No Rinse, Two gallons of water, Three Microfiber towels and enough tire shine to do four tires. That is all. No getting out the hose or drying with big towels or water blades or anything and the truck looks incredible. We just got my wife a 2012 Toyota RAV-4 Limited in Blizzard Pearl and it works great on her vehicle too. I have used this product 16 times (we have four vehicles counting the Subaru and Honda) since January and the results are great.
I did not start using this product to conserve water but it certainly does that. I started using it because when it is freezing outside the hose method is a PITA. So, thanks to you guys I am using a good product and will continue to do so!
*UPDATE* 01-04-13
Have been using the Optima No Rinse this cold snowy season too. It still works great on my silver TE, my wife's new CR-V (she hated the RAV4) and my son's black Subaru. If you have never used this product you don't know what you are missing. It is 32 degrees F outside and I just did all three vehicles in an hour and a half. My previous black 4Runner was cleaned with this product about 15 times and it never scratched. Amazing stuff!
Your post comes two days too late as I just bought a "isht" load of car wash items from Amazon. :redbrick:
Great review!
Thanks for the Review 1engineer. I have a black 2012 TE on the way and with living in PC, Utah, keeping cars clean is a real chore.
Looking forward to testing this product out.
Yes that is the stuff. As I said, I have used it 16 times and I still have half a bottle left. Works out to about $0.50 a wash.
holy crap. I just did a search for "no rinse", and jackpot, i found the thread. I wish all the dudes would use the search feature!
http://www.toyota-4runner.org/5th-gen-t4rs/108026-has-anyone-used-product.html
Thanks for the product review 1engineer, i'm going to buy this stuff. What did you use to dry the truck? Like a shammy cloth??
No. I use a microfiber 12"X12" towel, which is a little bigger than a standard rag. What I have found to give best results is: Wring out the wash microfiber until it does not drip. Wring out the rinse microfiber even more so when you use the drying microfiber the panel is barely damp. I can dry the whole 4Runner with one microfiber towel without wringing it out. Remember, you do each panel complete; that is wash with one rag, rinse with another then dry with another. So when you are finished with a door for example you have washed, rinsed and dried that door - then move on to another door. You can also do more than one panel at a time and even if it dries, all you have to do is re-wash or not wring your rag out so much. The most amazing thing is when you rinse, there is no "haze" or dirt residue on the panel. When you get done your wash rag and water looks like crap, your rinse rag and the water is still clear and your dry rag is still clean!
alright. thanks for the details there. I guess i'm going to pick up 3 microfiber towels as well. I left for lunch and went to get gas in the truck, while i was out i stopped by autozone, to see if they had this product in stock. They did not. I asked the kid if he had heard of a "no rinse car wash", he was like, "uhh what?"
also, filling up the truck at $3.95 per gallon. FML
What really works for me is using two buckets to wash the truck. One bucket with soap (car soap and a water treatment) and another bucket with clean water. Both buckets have grit catchers at the bottom. When I wash I dip the microfiber mit in the soap to load it and wash a panel of the truck, but before I "reload" the mit with new soap, I dip it in the bucket with clean water first to rinse it. After that ring it, then dip it in the bucket with the soap and keep going.
This way your soap bucket stays clean and you keep from reapplying dirt to your truck. Also helps to prevent those nasty swirl marks. And like 1engineer, avoid those shammy's and stick with a good quality microfiber towel. Just once piece of dirt under that shammy and you can kiss your finish goodbye.
Two bucket method is key.
ONR is a great item for all detailers. Very versatile as well with instructions on the bottle on how to use it as a quick detailer and a clay lube. It's a must-have product for those that like to keep the trucks looking good and preserve the sealant or wax longer. Winter washes with is the biggest win of all.
I get the 128oz bottle since I use it on three trucks. It lasts a while since you use only a couple of ounces at a time as stated before.
A great site to get it from, how to use it, properly detail in other ways, and where you can get high quality miicrofiber is Detailed Image - Premium Auto Detailing and Car Care Products, www.detailersdomain.com, and autogeek.net.
All are fantastic sites for detailers and access to forums.
Is this just for in between big washes say post-rains,snow,lots of raod grime,etc? Or does it work wonders on everything?
Whoa!!! you guys got me intrigued!!! just placed an order for this and the optimum spray wax made by the same company! can't find a negate review anywhere!! can't wait to give it a try...does anyone have any experience with the Optimum Spray Wax??? i also got suckered into ordering some good cobra micro fiber towels too!!!
I've been using optimum products since 2009. Make sure you guys are getting the latest (I believe v.3) of the optimum no rinse. People think I'm crazy when they see me outside washing my truck with what looks like JUST a couple buckets of water :lmao: And when I try to explain they still think I'm crazy. Fact is, Optimum makes great car care products. I also use their spray wax, spray sealant (Opti-seal), leather conditioner, and power clean for the wheels. When I clay the truck I use optimum instant detailer as a lubricant. You get professional results with little product and little time, good stuff.
I think i got the latest version.. i ordered it off amazon from palm beach motoring accessories.. glad to hear it works well!! i live downtown chicago and if i ever need to park outside my car is instantly dirty!!!
Thanks for sharing everyone. Definitely gonna give this a try. Just moved into an apartment complex so this will be very convenient for me.
patnewton
