Non Power Antenna to Tacoma Whip
slimatic
I tried searching forever for an answer on this, but couldn't find anything.
I don't have a power antenna. I have this ugly thing.
I want to do the Tacoma Whip mod
The "Taco" Whip Antenna Mod
Do I need to get an Antenna Assembly since its not a power already? Do I simply remove my current and attach the Whip? Or do I need to get both Assembly and Whip regardless?
From this pic it appears the Tacoma whip is a total replacement, so you just take yours off and put the whip on.
Tough part is routing the new antenna cable to the radio...
Ok, so does that mean I do not need the Antenna Assembly: part# 86300-35090?
I would only need Tacoma Whip antenna: part# 86309-AA040?
u need the hole set up the part that holds the antenna to the fender i got my set up at a junk yard for 10 bucks no antenna so i found one off a 92 pickup
i just did this and it cost me about $110 from my dealer go to the scrap yard and source the parts, that said it wasn't too tough, took about 30 mins and the hardest part was getting the mount up into position and bolting it in, feeding the wires was pretty simple just make sure remove the whole glove box to get the best access and feed the wire back into the original wire loom and make sure you get the rubber grommit leading into the body all the way in other wise you may end up with a puddle inside your truck, cool mod though, i like the way it looks and like the idea of not breaking anymore antennas
What's the length of that , 5 feet ? Do you guys who wheel often ever get into situations where that gets in the way ? Where I go wheelin ,at times , it's heavy forest and the trees sometimes close the route in tightly ( heavy bush all around the truck ) . Just wondering how far that baby will bend over before damage occurs .
sorry should add it's not 5 ft long quite a bit shorter then that i think and you could probably bend it like 50 degree before it'll break, it's still a steel rod in the center and not really a true whip that can bend 90 degrees and bounce back.
yeah i'm a big fan as well, i'm pretty much going this same route but just with different components, as in i got an arb bumper instead of a custom one, i'm going with the same lift size but different parts, different roof rack and different sliders i think (haven't ordered them yet) but there's no denying it these things look awesome once you have the full kit on them and jsmarine did a sweet job with his that's for sure.
Maybe he could use it off his fugly antenna?
ya thats what I really want to know.
because my current antenna is a non power antenna, will the new Whip fit into my current Assembly? Or does this Whip require its own Assembly
I don't want to buy the Assembly if I don't need to, if all non powered assemblies are the same.
Anyone?
you'll likely need the assembly-about $30ish or so brand new .
It depends-will your old one just unscrew at the base? Does it leave a male threaded stud or female threaded (hole)? If you are left with a threaded hole then there are screw on adapters to mate up.
try Toyota Parts Zone or other discount Yota dealership since you have the part number.
Don't spend $20 something for the mast (some say whip) itself. Almost any mast from a 1st or 2nd gen Runner will screw right on. If you have to have it in black then take some cheap spray paint to it.
Or just cruise the junkyards for a wrecked Tacoma or base level 4Runner. They may have all the parts you need....
I have 2 or 3 extra masts laying around the garage myself.
They have a lot of flex-but some guys mention that they prefer to remove their antenna before entering a car wash with those blanket type strips that slap all over your vehicle. Personally I just avoid those type of car washes ....
If you want to get really complicated you could go power antenna and just leave it retracted except when you really need it. A simple toggle switch wired up allows you to control when the antenna goes up and down.
The rear antenna in the side glass of the cargo area is typically all the antenna you ever need. If you have stock head unit it is probably still plugged in. If you have already gone to an aftermarket unit it is probably behind the radio just laying there.
Stay in touch if we can complicate your choices even further....
Rock Slide over on Yota Tech has done an excellent writeup on combining the antenna signals. Total cost under $15. I took his suggestions and now my antenna never comes up out of the hole unless I desire to hear far away AM radio.
I really, really, really want to the Taco Whip Mod. To that end, some quick research yielded this thread and The "Taco" Whip Antenna Mod.
The following is from the former:
PART 1 OF 2
The "Tacoma" Whip Antenna Mod
By: Bob_98SR5
Date: 12-19-2002
Tools Needed
Flat-bladed Screwdriver
Philips-head Screwdriver
10mm rachet wrench
Parts
Antenna Assembly: 86300-35090 (list price $36.94)
Tacoma Whip antenna: 86309-AA040 ($27.38 at my dealership)
Please note that the Tacoma Whip Antenna is not picture above. If you want the Tacoma black whip antenna, buy part no. 86309-AA0400 and NOT 86309-35100 or 86309-32011. Also, I've received some feedback that the part numbers may have changed. If so, just ask for the non-motorized antenna assembly for a 4runner and a black whip antenna for the Tacoma.
Thanks to UKMyers from Yotatech.com who provided the following part number in this thread for 2nd generation 4Runners: Toyota Part # 86300-35070 (2nd gen 4Runners)
Addendum: 5/13/06
Based on the information in this writeup, a Yotatech member figured out how to do this mod without removing the wheel well liner. Read here.
Disclaimer
I am providing this write up for illustrative purposes only. Perform at your own risk. Any mods (including this one) you perform on your vehicle is your responsibility. Commercial use of this write up will result in legal action as well as the undying scorn from members of the online Toyota 4Runner community. You've been warned.
Summary
One of the most common problems with any vehicle including the 4runner is its power antenna. Over time, the antenna mast's "teeth" usually breaks because the "teeth" themselves (that is part of the mast itself) wear out. In other cases, the mast is simply bends or breaks which will not allow it to retract back into the motor unit.
One solution is to buy a replacement mast, remove the old one, and hope that the new one feeds itself perfectly into the motor unit. However, many times the mast "teeth" breaks inside the motor unit itself, requiring removal and opening of the motor unit in order to remove these pieces of teeth.
An alternative solution is replacing the motorized unit with a non-motorized antenna assembly with a non-motorized (obviously) mast antenna. The advantage of doing so is that you really don't have to worry about anything motorized breaking ever again. Furthermore, the whip antenna is tough---I've hit many low hanging tree branches and the antenna just twangs itself right back into place. A motorized mast, I'm sure, would have snapped in half.
Step 1: Removing the Fender Flare and Running Board End Cap (front)
Depending on your type of fender flare trim and running boards, remove these pieces in order to access the wheel well lining:
After removing these trim pieces, you need to remove 2 of the 3 wheel well lining plugs. Here is a diagram of what you need to remove as well as a close up of one plug removed:
Step 2: Remove Wheel Well Lining
After removing the wheel well plugs, pull and invert the wheel well lining so you have enough room to access the motor unit. Don't worry, the material will not crack or break. The material is very similar to a kiddie pool, only much thicker and more durable:
Step 3: Removing the Antenna and Bezel Nut
At the top of the mast, unscrew the bezel nut by wrapping your flat bladed screwdriver with masking tape and putting the side of the blade into the bezel notches. Turn counter-clockwise to remove.
Unless you run like Speedy Gonzales, you might call your friend to help you here. To remove the broken mast, turn off your stereo and let the mast retract as far as it can go. Then ask your friend to turn the stereo back on. While it is going up, pull it up until it comes out of the unit. You will see the metal antenna and a long, white strip of "teeth." Some people have tried with some success to just pull it out, but my dealership advised me to pull it out this way.
Step 4: Removing the Motorized Unit
Unplug the power wire that is connected to the motor unit. Then unbolt the single bolt holding the motorized unit to the bracket inside the wheel well. Unfortunately I didn't take a picture of the motorized unit prior to removal, but here a blurry picture of the non-motorized one after installation (the bolt is the same):
You can now partially detach your motorized unit. You will see that there is a wire leading into the body of the 4runner. This is the antenna wire that connects to the back of your stereo. If you intend to possibly re-use the motor again, do not cut this wire (like I did). To remove it, continue reading below.
Step 5: Removing the Passenger Side Bottom Panel and Front "Radio" Panel
The antenna wire starts from the motor unit itself into the 4runner passenger compartment area, above the A/C duct, and into the back of the stereo. Here is the path it takes to get there:
You must remove both the passenger side bottom panel and front center "Radio" panel to properly remove the antenna wire. To remove the passenger side bottom panel, unscrew the following screws to remove the glove box and bottom panel:
To remove the rest of the radio panel, follow this excellent writeup that SLC_Punk wrote, which is contained in Yotatech's "Tech" section. Go as far as "Step 5" in Travis' write up and continue below or follow the writeup here under Step 3.
Am I not being clear about this?
I am aware of this write up. I linked it in my original post.
That is for a POWER antenna to NON POWER conversion.
In which a new Antenna Assembly is needed (Power vs Non Power)
I'm doing NON POWER to NON POWER.
My question, if I can't be more clearer, is that if I already have a Non Power Antenna Assembly, do I need to buy the one for the Tacoma Whip.
Will the Whip fit in my current Non Power Assembly or is it Proprietary? Will the Tacoma Whip only fit in that specific Assembly?
PART 2 0F 2
Step 6: Removing the Antenna Cable
Pull out the stereo as far as you can and detach the power and antenna cables. I believe the cable marked "2" (the furry one) is the antenna wire. Pull this one out and leave "1" as is. From my recollection, the "1" cable is the power cable.
After unplugging the antenna cable, follow the path of the antenna cable to the right and cut the zip ties in the four places marked here:
After you've done that, go back to the outside of your 4runner and then you can pull out the antenna cable.
Step 7: Attaching the Non-motorized Tacoma Whip Antenna
You can now bolt on the non-motorized unit. Then thread the antenna cable through the hole, run the cable all the way to the stereo, zip tie it along the top of the A/C duct, and then plug it into the back of your stereo:
Attach the bezel nut at the top of the non-motorized unit and screw in your Taco whip antenna.
I would suggest at this point to test the antenna connection before attaching all the panels you removed in Step 4. If the test goes well, re-attach all the panels in reverse order and enjoy hassle-free radio listening pleasure!
You can see two pics of the Taco whip antenna by clicking here.​
Your question is now clear as glass (to me at least). Sorry for the extraneous info.
As to the answer to your specific question, I'm afraid I don't know. Seems like it would be pretty easy to buy the mast only and see if it is plug-n-play with what you've already got.
Parts
I just bought from the dealer Part # 86300-35090 (antenna assembly)
It comes with a silver mast in the box and everything to install it.
It's pretty cheap considering that a power mast alone is close in price to the Taco assembly.
If you want the black mast you can buy the other part # 86309-aa040
Wait...so if I buy only #86309-AA040 (POLE SUB-ASSY, PULL TOP ANTENNA), that's all I'd need to convert my power 4Runner antenna to the black Tacoma whip antenna?
Incorrect Prelate-the power antenna assembly does not have a screw off mast attachment. You would have to change out the base unit of the antenna itself, running a new antenna wire to the head unit.
