Odyssey Group 34 - Whats been your experience?
I have the 34 PC1500 single battery and running the Dometic cfx65w. Just came back from Moab last week for a week. The 1st initial day before the trip when I got the fridge was concerning as voltage dropped down to 12.0v over the coarse of 12hrs. But after that, it maintain a 12.5-12.6v in the morning for every night i was there. From my understanding, the Dometic is one if the lowest power consumption fridge and I'm running a single battery setup, so i wouldn't be concern even for 2 days before start. You dont really need the spacers as i dont have the spacer on. And as for the 31m, it's nice to have the extra juice but I don't think I need it.
I just got the Odyssey 34. I needed a spacer on mine. I just cut a block of wood and put it on top of the battery and that works fine. I may buy an aftermarket batter holder.
I am on my second 31. I had the old Diehard 31m (rebranded Odyssey), I noticed @ 22 months the case cracked on the top and started getting weak voltage >12.3, returned it for full refund, bought a Odyssey 31m-pc2150 (before they switched the poles) I do have the “voltage booster” fuse.
My truck does fine if I drive it a lot, other than that I keep it on a NoCo smart charger as if I don’t make long trips it does slowly discharge. I personally believe the suboptimal charging is software/ECU issue. I have the TE edition 130 amp alternator, which should be plenty.
I am curious how everyone that did the big3 upgrade are doing, there were at least a few dozen that group buy’d the xp270 alternators.
Hi jrandom,
My 270-XP is still Great from 2015 (14.6 V @curbside idle), but my "35-AGMPC1400 Odyssey Extreme" is 8 yrs old now, and showing signs of poor storage capacity when using accessories...e.g. two 1200W Sub amps, LEDs, htr, wipers...etc! So I'm looking to replace the battery with an "ODX-AGM-34R-1500" 850 CCA (135 min reserve)... don't need my voltage sagging when accessories are running!
rigtec, cheers! :cheers:
Hi jrandom,
My XP-270 is still Great from 2015 (14.6 V @curbside idle), but my "35-AGMPC1400 Odyssey Extreme" is 8 yrs old now, and showing signs of poor storage capacity when using accessories...e.g. two 1200W Sub amps, LEDs, htr, wipers...etc! So I'm looking to replace the battery with an "ODX-AGM-34R-1500" 850 CCA (135 min reserve)... don't need my voltage sagging when accessories are running!
Very happy with mine!
Hey so has any of you experimented with alternate battery chemistries yet? As I see the one you want to replace is a "drycell". ODX-AGM-34R-1500
Since already dropping $300-400 on these it isn't much more of a stretch to look at alts. Curious minds want to know :-)
Hi jrandom,
Well A-Team...,
I ordered the new:"ODX-AGM-34R-1500T, 850 CCA (135 min reserve)" (from Amazon) on Saturday, and it arrived on Wednesday 2/15/23; "And I'm THRILLED!" I really had NO IDEA how depleted this 8 year old battery was; [installed on 5/29/15]. It always started w/o any trouble... cranking was slightly slower during the Summer, but that was a sign to me that it may be time to think about getting it replaced!
But last month, when I cranked-up the Mono-Block-Subs, (letting my rage out :rant:), I noticed that the "Tell-tale volt meter" on the instrument-cluster was swinging back and forth! I plugged in my 12V cigarette lighter voltage tester, and it was swinging from 14.50 to 12.85V and back; ...and you know that ain't right...
:wtf:
So it was time; I've NEVER had a battery that lasted for eight yrs, and giving me such "Trouble-free" Service across time! So I could justify the cost w/FREE S&H, was $367.79 (+ tx) $391.79! And this "Odyssey "ODX-AGM-34R-1500T has a lil' more reserve cap than the Odyssey Extreme AGM 35 PC-1400! Here are the manufacturer's details below should-ya wanna make an AGM swap:
ODX-AGM34R (34R-PC1500T) ODYSSEY Extreme Series Battery | ODYSSEY(R) Battery
Now: NO MORE "Tell-tale combination cluster swing; current/voltage is "STABLE"; as it should be, based on state-of-battery charge, outdoor temperature (14.59V-14.70V)...etc! For questions, hit me back here; or if a lil' discretion is needed, you can shoot me a PM... I hope it's fixed; I wasn't getting my msg's for more than a year...Lol!
~rig~ Cheers!
wwarren702
