OEM SR5 roof rack ?
8086bruce
I have a 07 SR5 with the factory roof rack and this morning I went through a car wash and the dryer blew off one of the rubber strips that lays in the channel between the front and rear mounts. It is about a six ft piece of rubber strip. I put it back on and it looks like it is just a friction fit strip but it is very loose and I can slide it back and forth. Has anyone else had this happen? I don't know if it should have some adhesive or something to hold it down. Any help would be great. Thank you Bruce
Never happened to me but check out the 3M products. I know they make double-sided adhesive strips that are widely used for attaching stuff to cars
I kinda have the same problem, I installed an urban runner rack the other day and the rubber strip on mine started coming out near the front of the driver's side, I keep tucking it back in but it still pops up sometimes. Mine is only 2-3" though not the whole strip.
I'm going to try some spray-on adhesive (3M Super77), I'm worried the tape I have (the 3M grey stuff like on ventvisors & badges) is going to be too thick and will make it bulge since I only want to fix 2-3".
How are they held in from the factory? Are they really just kind of laying in there? Or do the you some glue or something?
Looks like they're beveled and kinda snap in, but also have some sort of black glue under them. They also go under the rack feet, but that doesn't seem to hold them well. I think the 3M grey tape would work better unless I can find something like the black glue that's on it from the factory.
That's odd that mine did then... The black stuff on mine isn't on the strip, but is on the body and appears to have lost its bond with the rubber (or maybe it wasn't bonded in the first place?) Has yours come off on its own since you put it back in or does it just slide?
BillM777
