Official 3rd gen 4Runners on 35's Pic Thread
In the process.... :D
IMG_20120214_150628.jpg~original
Got the rear done today and ready for them... Barely got started on the front though.
to run what i have now i have stock front with 2.5" block lift, rear is 891 OME and 3" block, and over all a 2" BL. did some cutting and pounding on the front just for good measure. it ran 33/12.5 amazing.
got the 35" and hits a little on the turn when a ways in, going to do tundra trd front and LC 9s back.
and also have 4.56 gears so a little better than stock
EDIT: oh and no rubbing on the UCA because the rims have the back spacing for the 12.5" wide tires. no spacers.
but these things are a B***H to get on the hub... they are heavy and the lugs never seem to be where the wheel is.
I am actually pretty disappointed that you started this thread Bandit.... 35's have been haunting my mind a lot as of late, and now I have to look at all these provocative photos. This is proving difficult. lol
3rd gens on 35s = WIN
lol Rickashay, i know exactly how u feel... i kept telling myself i should jsut stick with 33s and not go to 35s but lately everyone keeps posting pics of them on 35s and now this thread. Now i find myself puzzled bc i think 35s and 3rd gens looks AMAZING!
Sorry to disappoint you guys...NOT!
Hey Bandit..... Since yours is similar to mine in the fact that you still have your sport flares do you happen to have any pics of how you modified your fenders?? Just looking for some ideas right now. I started a few rough cuts today but still have a ways to go.
To answer a few of the questions asked:
I run my tires at 34 psi for daily driving.
I don't rub on the frame in the front. Probably because I have 1.25" wheel spacers. I have stock UCA's.
I think the 1.5" body lift really helps with the wheel well clearance. Plus I did a lot of trimming/hammering to the pinch weld and firewall area. I don't have any rubbing.
It seems like most people who run 35's in 3rd gen 4Runners do the BL to help clear the tires. I know people who have the 1st gen Taco's, dont run a BL and tub the firewall, and clear 35's with only 2.5" of lift. I think I am going to try the later route when the time comes. Anyone here run 35's without the BL???
I'm doing mine with just a 1" BL. The only reason I did that was to allow me to tuck the drivetrain more, other wise I wouldn't have done it at all.
Yes it can be done, Trails Less Traveled did a writeup on it. Involves tubbing the firewall.
Yah, I've read through that write-up several times. I just have always wondered why the 4Runner guys seem to choose BL over tubbing most of the time....??? I guess it's probably easier.
Im running 35's with no body lift. The Trails less Traveled article inspired me to not do a BL. I did not tub though, I hammered till everything cleared. Take the front strut out and bolt the tire on and move it up and down, side to side and hammer back where it rubs. It took me a little over an hour per side in the front. And I had to remove the inner kick panel and trim it to get it to fit properly. But the result is that I have no rubbing with the exception of on the frame behind the wheel and on the UCA but that will be fixed tomorrow as I will be installing Total Chaos UCA's. A body lift may be easier but it is not necessary.
I did the same process with both my 98 and my 99 RIP.
IMG_3146.jpg~original
P1020876.jpg~original
P1000141.jpg~original
P1000140.jpg~original
Thanks I've been fortunate to have 2 really nice runners. I love my black 98 but really miss that 99. What part of Colorado are you in. Lived in Ft Collins a while back and loved wheeling in the Rocky's
A lot has to do with the actual tires chosen. There is a lot of variance on overall height and width between tire brands and styles. The 315/75ra6 Mtr's I am running are actually true to size. They run exactly 35" on the truck and are exactly 12.5" wide. I have seen 315/75r16s that are 34.5" tall and about 11 3/4" wide. The width is a big factor. I know the coopers run small, and all of their sub brands seem to as well, like Micky thompson, **** cepek ect.
I am running a 1" BL no wheel spacers and i still rub the fire wall after hours of cutting and pounding on it with a sledge with a 3 ft handle. There is no way that you can pound the firewall back enough to clear the MTR's with no body lift. Tubbing is the only option, and honestly i figured i would smash t and try it out then if i need to tub i will just cut out the smashed metal. You have nothing to loose
I know my friend has a taco on 35's and no >body lift and I sit at the same height he does. The body lift lets me keep the suspension down and keep a real nice ride.
EDIT im also running 5.29 gears with the 35's to make it drivable. Its perfect with a 5spd and 5.29s. maybe a little high on the freeway, but i rarely drive it in the freeway and if I do i just keep it under 65 mph. Not only do i get better mpgs but less tickets!
It's true my MT MTZ are really a 34.5 or so they are a full 12+ wide and the are on a 17" rim. Those MTR are truly sweet. I just put a set of Cooper STT's on my wife's 4th gen and they measure pretty much 35 straight up. I also am not running any wheel spaces. It changes the arc that the wheel travels and pushes it back into the fender well. I also have the 5 speed and went 4.88's because I spend a fair amount of time on the freeway and for freeway I still think it is a little over geared. But I also slow down to 70 and am getting just over 16 on the freeway calculated by hand. I think 4.56's and dual cases would be ideal. LOL
MaximussK
