Ok wtf am I looking at. Transfer case?
Riders of Lohan
Thank you! It's leaking!!!
Just had the transmission rebuilt... Now this is leaking.... Is that suspicious?
Bolts don't look like they have been removed recently
There is a yellowish fluid leaking around here. Is that transfer case fluid?
If I'm correct the T-case uses ATF which should be a red-pink color. they would remove Entire trans to rebuild it I would think, but they wouldn't touch the seals. If I remember correctly though the seals are fairly inexpensive to fix and take very little time to do (30 min +). Id bring it up to the shop and see what they say.
Wait a second Let me take a look at my runner quick that may be your main seal and in that case you may want to ask them about it. The fluid still should be a red color so it may just be residual assembly oil/grease.
Na. I think you are mistaken The T-Case in my 5speed Takes regular gear oil I use amsoil 75-90w.... but it could be different for others.
Ok that makes sense. I wasn't sure, but I see no reason why they wouldnt use gear oil. [MENTION=90245]Riders of Lohan[/MENTION] let me do a little research or maybe some else will chime in first.
Yes. That is your T-case.
NO. It doesn not use ATF.
YES. It uses Gear Oil.
What it looks like is leaking is the rear seal, just after the pinion flange. It's not hard to replace by yourself, [MENTION=44220]BigFishAllDay[/MENTION] did a write up on how to change the front and back.
It could also be from the shifter, if they didn't put it on right, or when they took it off.
Quick little tip:
Gears use Oil. Manual transmissions, t-cases, and diffs.
Automatic transmissions, while they have gears, are run by synchros. Anything automatic like that, is going to use ATF.
Quick little tip:
Good tip, I'll keep it in mind. I ran into confusion because of experiences i have had in the past. Our saturn 5spd called for atf so therefore all use atf in my mind :nono:
The more you know i guess lol
Thanks for your help
Quick little tip:
Thank you. Wish it was Saturday. Would love a day to research this and figure out wtf I am doing
Quick little tip:
For toyotas yes this can be used as a general rule. Chevy uses ATF in all aluminum/magnesium t-cases.
Sorry man ****ing iPhone and imgur app
It's all good man. LOL. If I had this Govvie hooked up to a TV screen, I'd be good. But I have to scroll all the way across the damn page to get be able to see the picture.
Load the pictures straight through Tap-A-Talk. that's what I ususally do. If you're using an app, there should be a setting for the size of the pictures that are getting uploaded.
And, that is why they fail....... :shrug:
Testing tapa talk
I pulled the fill plug out of the t case and fluid started coming out, so I am assuming that means it's full?
I am finding oil up at the top of the bell housing... Would this be normal for a seal leak? This can't be a cracked housing or something right? Seems to be riding fine....
booboltrope
