OME 10mm trim packer WITH daystar 1.5 spacer in rear?
DPR64
Can one use the daystar 1.5 rear spacer along WITH an old man emu 10mm trim packer? This would be then about 1.90 inches in height...
Trim packer and spacer install on top of the coil. Once under compression you will get double the lift. So if you install 1.5 thick spacer you will get 3" lift. Unless you are intalling a .75" spacer which would be the 1.5" lift and how it would be advertised. Adding 10mm trim packer will be double lift of that packer also so 20mm in lift.
A couple months old but I'll give my two cents... I would think using the spacers with 1 10mm trim packer would be okay IF you have the rubber cone isolator that goes inside the coil spring. If not I would just use the 1.5" spacer.
I don't think I'm reading your post correctly. Why are you doubling the measurements? The OP is talking about the rear springs not front, is that what you're thinking?
I guess I was not thinking that post through to well. The rear is not under compression like the front so it wont double ride height with the spacer?
No, in the rear you get what you put in to it. So a 1.5" spacer gives you 1.5" of lift.
Hmm... that sounds bad.
Thanks for that, I swore I got more when I added my 10mm, but now that I think about it, 10mm is about .4" and thats what I got im guessing. Thanks for the info!!
Ha ha. Yeah, definitely could be taken the wrong way.
Thanks for this. I've already installed my FJ coils in the rear, and then on a separate occasion installed 2 yellow OME trim packers (2 per side.) Still not enough to match the Swayaway coilovers on the front so now I'm pulling the trim packers and throwing in the Daystar 1.5" rear spacers and putting 1 trim packer back on the driver side.
Question is, should the trim packer go:
1.) between the coil and bumpstop?
2.) between the bumpstop and spacer?
3.) between the spacer and body?
How she sits now. New wheels and tires sitting in my garage.......
20150103_092129_zpskdrdq8wf.jpg~original
Thanks in advance.
Kraig
Thanks in advance.
Kraig
I'm not familiar with 4th gens. If that's what you're asking about. Do they have the upside down cone bump stop inside the coil? If so then put the 10mm spacer inbetween the coil and the cone.
Sorry about the misplaced post. Searching is good, but not when I end up asking the question in the wrong forum.
Ended up calling Wheelers and Dan said to put it between the spacer and the body. Will work on it this weekend.
Kraig
Hi sorry to revive an old thread and an old topic. I’m trying to do the exact same thing in my new to me 3rd gen 4runner. I’ve seen pictures where the trim packers went between the coil and bumpstop. And when using the daystar, they also went between the coil and bumpstop. I attached said pictures.
So if i’m using them in addition to the daystar spacers, is it confirmed that the trim packers go on the very top next to the body?
From top to bottom: body>trim packers>bumpstop>daystar spacers>coil
Or should it be
Body>bumpstop>trimpackers>daystar>coil?
This would mean the trim packers are securely inside the cone instead of on the very top with the possibility of them sliding out.
I’m inclined to think that the daystar with its concave shaped groove should sit next to the coil. Please correct me if I’m wrong.
I’d appreciate your feedback.Thanks in advance.
Just my 2 cents. I had those spacers for about 2 days before I just bought the right springs. It rode like crap because you were already preloading the spring and it felt like the back end was skating around over bumps and potholes.
Like I said, just my 2 cents.
"Or should it be
I’d appreciate your feedback.Thanks in advance."
^ this, although I wouldn't suggest two spacers. That looks like something might get squished out to one side after a while.
Thanks for the response. Did you have daystar 1.5 inch spacers? What did you replace them with and how was the improvement? Did you also replace shocks?
"Or should it be
Thanks. I think i might need just one, or maybe none. With my new rear moog springs, I measure 0.25 inch less on both front and rear driver side at 1/2 tank. Should I still put trim packers? Or is this as good as it gets? I don’t mind the labor of trying it on, and then off. Just trying to get feedback and see what other folks are getting/expecting.
If you generally have weight in the back end I'd put one on. If not it's up to you.
Yes, had the Daystars for a very short time. I didn't like how it rode. I replaced them with 906's and it rides great.
Dobinson 137 coils and don't look back. 2" lift and handles alot more weight. ExitOffroad.com will get you squared away.
I went from FJ coils with trim packers to the Dobinsons and love them. FJ coils were nice too but I wanted a little more rake.
Crookedcat
