OME 90004 Replacement Hourglass Bushings
Avwizz
Hey I recently got some used OME suspension parts, however fedex must have dragged the box behind the delivery truck at some point because it was badly damaged and as a result I'm missing the bushings for the front OME 9004 shock. could i use the current stock bushings as place holders until I find new ones? (wouldn't be long just a couple days or so) would just any 3rd gen 4runner bushing work or are these a different outer diameter for the OME springs. if i were to look for good bushings (full rubber I assume, not polyurethane) what brand should I definitely check out?
thanks!
waterman2258
