One cause & fix for "VSC TRAC" & "VSC OFF" lights, Zero Point Calibration
If I don't use the code reader in the right order, I trip the zero point cal problem. I can't clear it by using the battery disconnect, so going through this procedure solves that issue.
I only put the reader on now when the car is running and I wait for it to ask me to turn off the engine and after clearing codes, I take it off. Otherwise I am back to this procedure.
In any case, I was recieving O2 sensor code PO138 and I found a work-around and wrote it up here:
http://www.toyota-4runner.org/4th-g...-lights-o2-sensor-work-around.html#post896469
Basically I am fooling the computer into thinking that there is nothing wrong (and there isn't since I passed emissions) and eliminating this annoying and dangerous condition. My wife and kid mostly are in the car and I want the VSC working.
I tried to fix my transfer case actuator leak with a new o-ring today by taking it off and then re-installing it. The first time back on the truck, I got a horrendous grinding noise, all the lights (VSC/ABS/etc) went on and I couldn't get the truck out of 4LO. ugh...
I cleared the CEL code p1782 and then used this thread to do the 'zero point calibration' and cleared all remaining the faults.
I think the actuator was not engaged completely and it threw the P1782 code along with the VSC/ABS lights.
After removing and reinstalling the actuator, things seem to be working again. Other than needing to replace the oil seals on the actuator which got buggered up on the reinstall, the truck is back on the road.
Cross post from toyota120.com - hoping someone here might be able to help...
I've got a similar but not identical issue with my '05 V6 4WD...
It goes like this.. When I start the car everything is normal [no warning lights of any kind]. If I put the car in drive and start driving in a straight line everything stays good... When I turn the wheel I get solid slip indicator, TRAC and VSC OFF lights.
Turning the car of and starting it again resets everything. I've also noticed that I can cause the lights to come on by just starting the car, leaving it in park and turning the wheels.
There is no check engine light and I'm not getting any codes when I hook up an OBD reader. With the engine running I have gone through all the wires that connect to the sensors on the front hubs, jiggled them and not been able to recreate the issue.
ABS still works but TRAC and VSC are definitely not [pretty fun actually].
Any thoughts much appreciated!
works!!
Due to a mechanic who didnt know how to use the reader, I also got this problem. Followed the steps and it worked like a champ! No other side effects too. Thanks MicaBlue03! Posts like that really add value to the boards!
Have the same three lights with the sometimes mentioned rough idle at startup.
I disconnected the battery yesterday and the lights cleared for the rest of the day, but after the vehicle sat overnight the same thing.
I've heard the head gasket could be suspect, but has anyone had this issue and had it be something else?
Thanks.
2004 V6 Sport VIN JTEBU14R348028292
ABS Light on, VSC Off Light on, VSC Trac Light on
Get to step #3 in TSB BR005-003 or TSB BR001-04 and upon shorting the terminals 4 times the ABS light turns off and then starts blinking 3 times pause then 1 time. The VSC off light also turns off and then the VSC Trac light starts blinking 4 times pause then 3 times. Does anyone know what this means? I am unable to get to the light to go off on its own in step 7 or stay off while driving.
Help!!
Please someone help me... I have tried this procedure several times to the T and it hasn't worked yet...
I have a 2004 SR5 and have recently added a lift, so heres the story. I added the FJ swap + day star 1/1.5. After doing this swap with another member on here, we realized the VSC TRAC, VSC Off, and ABS lights were lit up. We then realized we had probably ripped the chord in the process of adding the spacers SO he cut the wire apart and spliced some new wire together, I added it and it worked good as new. However, the MAINT light was on and the TPMS light lit up as well.
So then I take the car in for an alignment and now the MAINT light is off, the TPMS light is off, BUT the VSC TRAC VSC OFF, and ABS lights are back on again! I continue to drive down the road and periodically they will go off for a 1/4 mile but then light up when I hit a bump or anything.
I have tried this procedure and the lights do go off when I make a connection, but after I turn the ignition back to the on position and the jumper cable is unhooked, all 3 lights are lit again and don't go off. I have repeated several times with the same results. If anyone has any secrets or tips it would be GREATLY appreciated.
PLEASE someone help me figure this out, as my car won't pass inspection until it has been resolved. Many thanks, as this forum has helped me with countless problems and solutions in the past. You guys and gals are the best!
I have the exact symptoms as you describe in a 06 Sport. Did you find the problem?
Hi All, glad found this forum. We have a 2003 RX300, one day the CEL and VSC came on. We checked the OBDII code and it was a bad Oxygen sensor. I replaced the sensor and sure enough the CEL went off. The only light remaining on is the VSC. I tried the Toyota Procedure to do a Zero point calibration using pins 4 (CG) and 14 (Ts) in the procedure found in http://www.toyota-4runner.org/attach...-dtc-c1203.pdf
It seems everything is fine till I get to point 11 on that procedure. Instead of the VSC light blinking, I get the ABS light blinking. And as soon as i start driving the car the VSC light comes on again.
One more clarification just to make sure Im doing this right. In step 9, I short the pins and they remain shorted right?
Also I read somewhere that it may actually be TC pin that needs jumping not TS. Any truth to that?
Thnaks I much appreciate any feedback
Great info
Thank you very much for this very important piece of information. We have a Toyota 4runner 2004 at our shop and couldn´t find a way to diagnose and calibrate correctly the VCS system. Now we have and our customer is very pleased, as the dealer in Costa Rica doesn´t service cars not sold by them. Again, thank you very much.
Daniel Murillo G.
Autoservicio TSO
Costa Rica
If you suddenly have the "VSC TRAC" and "VSC OFF" lights in your dash, this post may help you fix the problem yourself. The information here applies to 4th gen 4Runners that use the ISO protocol rather than the newer CAN protocol for their OBDII interfaces to code readers, ECU programmers, hand-held testers, etc. The OBDII interface includes several different protocols (methods of digital communication) and they all use the same physical connector, though with some different pins. The connector is located at the bottom of the dash on the driver's side and in the 4Runner it's covered by a small black cap.
4Runners switched from ISO to CAN around 2005 though this information may also apply to newer 4Runners with some modification. That is, newer 4Runners may display trouble codes and reset sensor calibration values in response to the connection of different (than earlier 4Runners) pins together than the ones described below.
Several posters have discussed similar problems, described in several different threads. I'm reluctantly starting a new one, with a more specific title (including the exact name of the two trouble indicator lights), in the hope that searchers will more easily find a solution.
The specific behavior: On startup, the "VSC TRAC" and "VSC OFF" lights come on and stay on. The ABS light may or may not come on. On subsequent starts the lights will come on temporarily as usual (as a bulb check) and then go off. They come on again and stay on as soon as the 4Runner is moved. The "check engine" light does not come on. This behavior begins after the vehicle has been hooked to some sort of OBDII code reader or engine tester or data logger, etc. Though the lights are on, no standard OBDII problem codes are detected by a regular code reader.
Cause: The code reader or other OBDII device has attempted to communicate with the 4Runner using the CAN protocol (involving pin #14) and this has caused the 4Runner to erase the "zero point calibration" numbers in its memory. Without these numbers it can't get accurate information from the yaw rate and deceleration sensors (in the center console near the gearshift) and so it disables traction and stability control functions.
The fix: Perform the "zero point calibration" procedure as described in TSB BR001-04. This procedure can be performed without special equipment such as a hand-held tester or OBDII reader. You only need the equivalent of a jumper wire to short together two pins of the OBDII connector at the right time and the right number of times between switching the 4Runner on and off. More detail is included below, leveraged from my other posts.
Why this doesn't happen every time a code reader is used: The code readers usually use the pins and protocol of the OBDII connector in a specific sequence, trying first to establish communication with the vehicle using the oldest protocol. They then try the pins and protocol of newer protocol standards. Usually the code reader would be successful in its first try at establishing contact with the 4Runner using the ISO 9141-2 protocol, and there would be no problem. However these communications schemes are not foolproof and occasionally the ISO protocol attempt fails. Then the code reader tries newer protocols including CAN (controller area network). It's this CAN attempt, which toggles pin #14 (the CAN data pin) that accidentally tells the 4Runner to erase the existing zero point calibration data. Since the 4Runner (this vintage anyway) can't communicate by CAN protocol the tester re-tries the older protocols again and eventually succeeds in setting up communication by the right ISO protocol. But by then the calibration data has been erased.
The calibration, by the way, is simply a matter of telling the 4Runner VSC/TRAC computer "your yaw rate and deceleration rate are currently zero" and to save the associated values. Then the output from the sensors can be interpreted correctly.
Detail (may be helpful if you're going to do the calibration procedure yourself): The SST (special service tool #09843-18040) specified in the service manual appears to be essentially a Y-shaped test lead and is variously called a "jumper wire" or "diagnostic check wire." It's used in this case to repeatedly connect and disconnect the chassis ground (CG, pin #4) and Ts (pin #14) terminals of the OBDII connector (referred to as DLC3 in Toyota-speak). The connection/disconnection sequence and timing are described in the service manual and in several TSBs. OBDII connector diagram and pin descriptions are in TSB BR005-03.
Since the OBDII connector is at the lower edge of the dash and pointing down (right above your left foot when you're sitting in the driver's seat) it's rather tough to reach in and do the shorting to the appropriate terminals of the OBDII connector with a test lead. Especially since you're supposed to avoid moving or shaking the vehicle when you're doing this. BTW, the OBDII connector usually has a black snap-on cover over it to keep out grit, etc.
Therefore I took a couple of pieces of insulated wire about 24" long each and taped them alongside each other, and stripped both ends. To make the wire fit securely in the (female) terminals of the OBDII connector I soldered a 3/8" length of metal (cut from a heavy paper clip) to one end of each of the wires. I chose a pin size so that would fit securely in the female terminals of the OBDII connector but wouldn't distort them. I used some heat shrink tubing around the solder joint to reduce any chance of accidental shorting.
After plugging the two pins into the OBDII connector (with the other ends held apart) I was able to hold the other ends of the two wires in my hands and touch them together at the appropriate times to connect the pins of the OBDII connector. I had a helper in the passenger seat to read the instructions from the TSB to me in sequence.
This is not very hard to do, and one need only be careful. It's easier to do with the Toyota OBDII tester, of course, and would only take 5 minutes. You might be able to get your dealer to do it gratis, but you might also be charged some minimum labor hour rate.
BTW #1: Doing the sulfur TSB or others that require the replacement or reprogramming of the engine computer or the VSC computer will also require this calibration.
BTW #2: I verified that when the lights are on the VSC and traction control are indeed inoperative. ABS is working, though.
BTW #3: Shorting other pins (such as #13 Tc) at the right time can cause the appropriate dash indicators to blink in sequence to reveal trouble codes other than the OBDII ones. A generic OBDII code reader won't give you this data, and you need the service manual (physical or online) to make sense of it. I believe there is a specific code to tell you that the zero point calibration data has been lost, but I didn't look for it.
BTW #4: In the 4Runner of this vintage the OBDII connector pins populated are 4, 5, 7, 9, 13, 14, 15, 16
[Sorry about the long post, but I wanted to include the kind of information I'd want if I encountered this problem and wanted to feel comfortable fixing it myself]
Worked like a charm
Thanks for the original post and instructions. I had this problem where the lights were showing (but not the engine light). I had just bought the vehicle from another person, and it had the lights on when I looked at it. They had lost the gas cap, and I think they took it to Autozone to read the code (being caused by the gas cap) which affected the ZPC. Took it to an independent shop who immediately identified the problem as noted in this thread. Please to have the problem fixed for a mere $40.
Bad cat
Anybody know if this works the same for a 2007 4runner with the V8 and 4x4?
Lucky yall, according to the Toyota dealership I have a bad cat and a leaking front pinion seal! $1600 worth of work! With mine being a v8 it has two cats and the other one was replaced 15,000 miles ago. Starting to wonder if this is going to happen again in a few years.
What was the fix?
So what was your friends fix?
Finally got mine sorted out and will very much like to thank everyone in this forum, you guys are great.
The Stealership was insisting that my Yaw Rate Sensor was bad and needed to be changed at a cost of $885 (parts only). I showed them a hard copy of the TSB but they also wanted to charge $133 for the Zero Point Re-calibration regardless if it was going to be helpful or not. :confused:
So I got a contact of one ex-Toyota Service Tech who now has his own shop, took my T4R to him and, in less than 5minutes, he got everything sorted at zero cost. Amazing!! had to give him something for beer though which he reluctantly obliged.
Took my ride out for a spin and the VSC now works again like a charm. phew!!!!:D
Saved me $700
Thank you so so much for this info. My mechanic was telling me I needed to buy a $700 sensor. I did some googling, found your post, read the proper TSB (TSB BR005-03) for my '03 4 Runner and I fixed with WITH A PAPERCLIP!
Then I took the TSB up to my mechanic and gave it to him and told him I fixed it with a paper clip and here's how. You could have pushed him over with a feather.
:lol:
Only read the excellent first post and I got all the answers I was looking for except one. I first encountered this problem after plugging an Ultragauge into my ODB2 data connector and Christmas tree of VSC lights. My question is will recalibrating the zero point data will do any good if I wish to continue to use the Ultragauge? I assume the gauge will ping the #14 connector every time I start the truck and erase the data again?
Also when the 4Runner is stopped and my foot is on the brake pedal the ABS light flashes intermittently and then goes off once the vehicle starts moving again. Is my ABS still functioning or not?
And FWIW I could care less if my VSC works I just want ABS. I know the VSC and TRAC isn't working because I did an AWD (I have a v8) power slide on dry pavement without any throttle cut out or annoying beeping.
to check if ur abs is working...i think drive at abt 15 to 40mph and jam the brakes suddenly....if the abs is functioning..it wwill kick in and the pedal will pulse under foot.u will feel it and a thump
2001ATL
