One more question for those that have REVO's
gqllc
I just ordered a set for my 2008 4 runner...What tire pressure are you guys running for on the street and off road? THANKS!
Steve
40 psi on the street and approx 15 psi off road, depending on how rocky or on sand.
Koz
So nobody adheres to the Toyota tire pressure sticker or what Bstone recommends which is 32 psi? At 6psi plus/minus recommended setting, tires are vulnernerable to structural failure, sidewall damage, overheating and irregular tire wear. Is it any wonder that there is such a huge range of tire wear issues when people don't adhere to the engineered standards?
Unless you're running higher load tires with reinforced sidewalls, I think I'll stick with 32 like it says, monitor and adjust as necessary, and keep on getting 5-10K more miles than the warranty mileage just like every set of tires I've ever owned.
Could not have said it better. In addition, not sure about Koz's off-road experience, but IMO 15 psi is probably too low for the REVOs off-road. REVOs are not off-road tires...they are highway tires with a slightly more aggressive tread. The sidewall is nothing to write home about. Therefore, i would only lower it to 15 psi if you're on sand with no rocks. Anywhere else, i would not. Rocks will kill the REVOs sidewall at 15 psi.
Valid to a point...
Here's where some grayness enters in: My stock Michellins have a load capacity of 2337lbs @ 35psi. The Revos carry 2337 @ 44psi. (I compared
If I was and when I have run stock tires on other vehicles I've followed mfg's recommendations .
After market tires I follow those recommendations as stated on the tires and what handles best for me or what the tire mfg recommends. Done it my whole life , never had a problem.
( I think Koz has "E" rated Revos )
I run them between 34 and 36 psi, just as I do with the tires on the Camry. I find above 36 psi to be too "bouncy" for my taste. And I like the ride at 34 a bit better than at 32.
My $0.02.
I've run mine at 34 for the last year as well. I like the ride at this pressure and have noticed they wear very well and look almost new.
As others have said in past threads on this, it is a matter of driving habits, how you like your vehicle to ride, and the vehicle itself.
IMHO, relying on the door sticker PSI recommendation as the 'standard' or any tire you chose to mount on the vehicle, is not a 'rule' I chose to follow. How can one assume that the proper tire pressure for the Bridgestone H/T is the same for any other brand or tire type. Look at what happened with the Firestone/Explorer tire issue. The Ford thecommended tire pressures for the Explorer were chosen for vehicle ride reasons, not safety or tire wear. I'm not saying that Toyota is recommending a tire pressure that is unsafe, but it is only an average number, and can't possibly be correct for all tire types, and driving conditions. It is up to the user to do their homework, and come to a PSI setting that best meets the needs of the tire, and their driving style. Toyota knows that most users aren't going to take the time to do the homework, so they make an average choice for them. Hell, the average user probably doesn't know what their present tire pressure is, and most likely checks it less than twice a year.
I run my oem H/T's at 37, and my Revo's at 35. In my testing, I have found those numbers are the best settings for each tire, based on what I have determined for the vehicle handling control I prefer, and acceptable tire wear.
Others may find that a different number will work best for their situation, and that's fine. I just don't think the number on the door sticker should be touted as the 'holy grail', must be followed rule. end all answer.
