original use of switch on 86 4Runner
CathyG
I have a paddle like switch right above my cd player and below the ac controls does anybody else with an 86 4Runner know what this was originally used for? My 4Runner was rewired really weird and it sometimes doesn`t start because something has drained all the battery power. I`m having trouble finding the electrical drain and since this switch makes my passenger side window go up and down regardless of whether my key is in the ignition or not I think it might be the drain. I think knowing it`s original purpose might help the mechanic to find the right wires faster.
Here`s a photo of the switch. It`s right under the cigarette lighter.
6579cac0.jpg~original
Switch
CathyG,
I can pretty much say for sure that that switch isn't original. Somebody put that in, probably to work the window, as you say it does now. Can't say why it might be draining the battery...
Craig
From the looks of the other hole adjacent to the switch in question, I'd say there were a pair of them installed at one time. They kinda look like auxilliary, external light switches, but maybe a previous owner used them to replace bad door switches.
Mike in AR
In my parents' 1986 4Runner, that location houses an 'Overdrive off' light on their automatic 4Runner.
Hope this helps,
Khany2002
I`ve installed a Battery Brain to disconnect my battery without messing with cables and it seems to be working for the most part. I`d bring it to a shop but most mechanics refuse to work on it because my wiring would take hours to go through.
The first guy who worked on my car told me the harness and connector were cut and there`s no way the window will work without it so I`m just going to have to live with it. That was before I realized this switch controlled the window and it worked.
TOYOTABOONE said:
The location of that switch is where the antenna switch usually goes on 1st gen's that had power antenna's.
That makes sense. My antenna has to be pushed down or pulled up by hand. Soon as I can find a more reliable shop I`ll ask them about it.
