Ottratw switch placement
MOOSERunner
Hey guys im trying to put my switches here like mikey. How Would i cut this piece to make room for the switch holder?
How do i actually cut it though. Using what tool
Lots of options Hand Saw, Miter Saw, Band Saw, Razor blade (lots of work) ,Water Jet, Chainsaw w/ proper jigging........Sorry
I used a hand saw and it made quick work of it, used sand paper to clean the edges (it was a rough cut blade, and even though its hidden I felt better cleaning up the edges)
EDIt: I could not see the OP's picture so I thought he was referring to a different switch placement
My bad, I could not see his photo for some reason at the computer I was on. While I didn't put my switches in that location I would use a dremel tool and then a razor knife and sand paper for any final trimming...
I used a dremel and cut through it. Go very slow and make sure you don't over cut. Then use a X-acto knife to fine tune it. You will also have to cut down the plastic flap that covers the shifter. You will see what I mean when you open it up and put it in park.
tuṣṭāva
