Overheat again
firebiz16
I have a1995 Toyota 4runner 3.0. the water pump, t-stat, timing belt, plugs, wires were replaced last week. The radiator is fairly new too. The problem is, it can idle for an hour and stay at normal operating temp. I drive it for ten minutes and it starts to overheat. I've noticed that I can put it in neutral and rev to 4000 rpms while on the road and the temp gauge goes right back to normal. The head gasket was replaced about 2 years ago. I'm not getting any white smoke or loosing any coolant.
The check engine light is on due to a faulty "knock sensor" which does make it run rough, but I don't think that has anything to do with the overheating.
Yep, the clutch should be noticably louder, then quiet down, but still rotate.
After you have wrmed engine up, check the clutch friction. It should rotate easily by hand with some resistance (with engine OFF !!!).
Deno91
