passenger power window
t4r05
Hey guys, new here, but bought a 95 4runner I'm going to flip once I get everything working properly. The one problem I'm having a hard time figuring out is the passenger side power window.
The window will ONLY go down with the switch on that door. The master switch on the driver door does NOTHING to the passenger window. The passenger window switch won't make it go up, but it goes down just fine..
Has anyone heard of this problem? I already switched motors/passenger switch from a junkyard and that didn't do anything...I'm thinking if I replace the master switch it could fix it, which is my next step right now...thanks
my 4r has manual windows but on another car I used to own (a MB Diesel) if the main unit on the drivers panel was not working properly it would wreak havoc on the indivdual switches or make them not work at all. Not sure if that could be an issue on a Toyota but once I replaced the main unit for the driver in my Benz, all the windows started working fine.
Mark
alright, yea I'm thinking if I replace the master switch with this one I'm watching on ebay it will hopefully work..if it doesnt from there then a wire must be bad. thanks for your help
