Pic request 2.5 or 1.5 daystar lift on 265/75/16's
hamiltonj2w1
I have looked on google and searched on here can't find any decent shots of a 3rd gen with this setup. I had the daystar setup on my 03 with 265/70/17's and it looked good but the 4th gens sit alot lower then 3rd gens.
I am considering just going with the daystar 1.5 now because I don't want 285's nor do I plan on new springs or struts anytime and for my needs right now a spacer lift is just fine.
Here you go: 265/75/16r w/ daystar 2.5" lift.
NewLift.jpg~original
TNMud2.jpg~original
317.jpg~original
The problem I have with this setup is that it will sag over time. I have a decent amount of weight in the back of my runner but it sits an inch lower then the front. You can see the sag here in these two photos
0042-Copy.jpg~original
Jiggwater34.jpg~original
Here is my old ride with 1.5" spacer in the back with 99 tall coils, and a 1" daystar spacer up front, regular coils. Then sitting on 265/75's
hey im looking to do the daystar 1.5" lift cause im getting some rubbing with my 265/75 duratracs on stock 98 coils, which are the second tallest coils next to the 99s by a hair. but im trying to decide if i should go with the 1.5 or the 2.5? they are the same price but i think i would run into more problems with the 2.5 lift. how did you like the 1.5 with 265/75's?
Do you have to compress the front springs/struts to install the 2.5" spacer? Or does it just sit on top of the coil/strut assembly?
Didn't want to start a new thread, so figured I would ask here.
I know I am reviving and old thread here...just wondering if there are more pics of 1.5" or 2.5" daystar lifts with 265/75/16 or 275/70/16...thanks
want the 2.5" but already have 275/70/16 bfg rugged terrains that I just bought and do not want to look too small for the lift...want it to look proportional...thanks
I have a short video walkaround of my truck after I did my lift and got an alignment; it isn't a Daystar lift, but it has ToyTec 2.5in spacers in the front, and Fat Bob's Garage 2.5in spacers in the rear. I have 31x10.5R15 tires which are roughly equivalent to 265/70/R16 tires (those have a diameter of 30.6in vs mine at 31in). The video is below.
thanks that does help a little, I am torn between a 1.5" and 2.5" daystar kit, worried if I go small I will wish I went big, and if I go big worried my tires 275/70/16 will look small, tough decision...3rd world problem I guess :)
If you get the 2.5in lift, your truck will look roughly the same as mine. I can take more pics of my truck on Friday if you want (the lift settled a tiny bit after driving a few thousand miles). Just let me know if there are any specific angles you want. I know I went through the same decision making process when I was piecing together my lift, so I'm more than willing to help you out.
Yeah you know that would help a lot, a pic so the side of the truck is at 10 o'clock, 12 o'clock, and 2 o'clock position would be awesome, I really would appreciate the pics
I really appreciate the help with those
FWIW: I only got 1.875" of lift in the front with my 2.5" Daystar spacers. I would go with the bigger one.
Not to steal the thread but I am wondering if your fuel mileage suffered much when you put lifts on your vehicles? I want a lift but also don't want to change tire size. I drive about 100km per day and fuel makes a big difference to me!
My gas mileage didn't change at all when I put on the lift. The only thing I did to negatively impact my mileage was a cold air intake (this is coming off soon when I install my turbo kit), and the BFG All-Terrain tires.
Ok, I'll get on that on Friday (might snap them tonight if its not too dark when I get home).
OK cool actually that does help, in trying to figure it out I want to make sure it looks proportional so if I do not get the full 2.5" that would work, the other thing I keep thinking on is I have a 2001 which is already 1" lower than the 99s, so that makes me want to go big, I appreciate the info
to your point, yeah i dont think the lift would affect you mpg, it is going to be the weight of any new tire for sure...and then perhaps someone else can comment the size of the new tire??
obviously when you go from 265/70/16 to 285/65/16 you are not only adding weight possibly going with a more off road tire P rated to LT rated, which adds additional strength (and weight in the sidewall) but you are adding more width and sidewall which adds more rubber as well...
The thing I am not sure of is does the size actually affect mpg? aside formt he additional rubber weight idk?
Also mpg could be effected by width of tire, how much tire is actually in contact with pavement, right.
a p rated 265/70/16 should get better mileage than a p rated 275/70/16 because of slightly more rubber and less contact with the road
To put it simply, in general, the larger the tire, the worse gas mileage. In the realm of 33s, a narrower one (255 width) will get slightly better mileage than a wider one (285 width) because of the smaller contact patch with the road and thus lower rolling resistance, but overall, the larger you go, the worse mileage you get, and there's not much you can do about that. My truck came with the tiny P225/75/R15 tires, which netted around 20MPG out of my 4 cylinder 4Runner, but when I upsized to LT31x10.5R15, that dropped to 13-16MPG city, depending on my driving style/how long the truck sits idling.
OK cool actually that does help, in trying to figure it out I want to make sure it looks proportional so if I do not get the full 2.5" that would work, the other thing I keep thinking on is I have a 2001 which is already 1" lower than the 99s, so that makes me want to go big, I appreciate the info.
Also, for what it's worth, I got the full 2.5in out of mine, which settled down to about 2.25in all around after about a thousand miles. Since mine is a 97 2WD 4 cylinder, it sat about as low as your 2001 when it was stock, so what you see on my truck is about what you'll see on yours if you go with the 2.5in lift.
Alright, so both of the images show 265/75/r16's:
BEFORE the Daystar 2.5" Leveling Kit:
IMG00093-20100123-1551.jpg~original
AFTER:
IMG00216-20110408-1902.jpg~original
Thanks, these two pics actually help a lot as well, the difference in springs i think from ealier 3rd gens to the 2001 and 2002 that sit so low really do not make the 2.5" spacer look overly huge, I appreciate your posting very much, very helpful!
MikeV5280
