Picture Request: 285s on Trail Edition Rims
Here's mine.
Hello,
I just purchased the Toytec Boss Aluma 2.0 lift kit with JBA UCA'S. I'm wanting to keep the stock TRD Off Road wheels and put Falken Wildpeak AT3 285/70 17 tires on them, but I have two local shops telling me that I need to put spacers in so that the tires don't rub on the UCA'S. Is this true? I think I would rather do 275's or get new wheels if it is true. I'm not a big fan of wheel spacers.
Thanks for the help
Hello,
Thanks for the help
Spacers will make it rub worse on the frame and front fender. You will have just enough clearance on the UCA’s
Guys, I don't know if it is the pictures or what. My 2020 trd offroad wheels look more shinier then a lot of the ones in this list. Some of the pics the wheels looks like a machined metal color or is it just the pic?
Hello,
Thanks for the help
I have Nitto Ridge Grapplers in that size and I rub at full lock. You can see it on the most outer part and bottom there. Enough to take the powder coat off.
I don't think I rub too much now that a shop gave me some positive camber or just at 0.0 from what I remember.
Edit: on yeah, on stock trail wheels with no spacers.
So would I be able to do 275's without spacers or rubbing?
If I wanted to for sure do the 285's would a different offset wheel just be there better option?
Here is mine. I use 1" Bora Wheel spacers. Had to do some minor trimming on the front bumper, but not noticeable to 99.9% of people.
Code:
I have a Pro with the Pro wheels running 275’s. I added 1.5/1” spacers which makes it about 2.5” up front as the Pro is 1” higher stock than the other 4Runners. It also comes with the front fender liner mod done at the port. I did not have to mod or remove my mud flaps and have no rubbing at full articulation off road.
Next time around I will probably run 285’s. Plenty of Pro’s running 285’s with a2/1.5” spacer lift and no rubbing. The key is the offset of the Pro wheel. I use to run 285/75-16’s, the equivalent of 285/70-17’s on my 2001 4Runner on 16x7” oem wheels and could air down to 15lbs. without issues. I had a slight rub after years of use on the UCA that left a mark like the previous member showed on his UCA.
Do you have more pictures of the front? Looks like you are running a new style front bumper but with 2010-2013 headlights? Interested to see how that works.
he isn't running preface lift headlights.
Are you using 1" Bora spacers all around? I haven't pulled off my wheels to measure the stud length, any issues with clearance on the studs. This spacing looks perfect balance of clearance while staying under the factory flares.
Also, Are you still running only a 1" spacer out back.
Weights?
Not to hi-jack but do any of you guys have these weights on your wheels? The tire shop mounted the traditional crimp on weights on the inside rim. I get why they are there but I didn't notice them on my 2017, maybe they were painted black? Every wheel on my 2020 has them in different locations and quantities. Each section is 1/4 oz.
I'm about to have a shop install the Toytec/Bilstein 3" lift with SPC upper control arms. I want to fit 285/70/17 Falken Wildpeak AT3 tires but I am concerned with rubbing on the UCA with the trail wheels having a +15 offset. Has anyone in this thread had any rubbing on UCAs with aftermarket UCAs?
How'd it go? We have the same wheels and are looking at similar sized tires.
wayblom
