True Plug-N-Play
I purchased Brian's rear camera dongle and video selector kit about three weeks ago. I was really excited about the two solutions he offered because I really wanted a front facing camera for offroading and I wanted something that didn't require permanently splicing into the factory harness of a $40k vehicle.
The rear camera dongle went in perfectly, but because of my own ineptitude, I couldn't install the video selector kit. For the life of me, I couldn't remove the wire terminals from the factory plug. I wrote to Brian and he sent many emails and even created a video to try to help me. Unfortunately the 2013 plug was a little different from the ones on his 4Runner and using a pin wasn't working for me.
Finally Brian took it upon himself to create a custom adapter for me that would be truly plug-n-play. He sourced the factory Toyota plugs and built an adapter that integrated the RCA plugs.
I got a chance to test it out this morning and it worked perfectly. It took me 5 seconds to plug in the adapter and everything worked! Yahoo, I am now able to feed in my front facing camera with no pulling terminals out and no splicing.
Here is the **PITA** plug that was causing me the problems. You need a special tool or be really good with a pin to pry the white retaining clips out. I tried for two days and couldn't remove the terminals.
Here is the adapter Brian built for me. You can see that the RCA plugs are integrated.
Here is the the female connector from the adapter plugged into the male factory connector.
Here is the male connector from the adapter plugged into the NAV and this is what it looks like complete. < 5 seconds, click, click, and you are done!
If you are looking for something plug-n-play or you are not that good with wiring, check out his products.
I think Brian may soon be offering this adapter for sale on
his site and/or he now offers to make custom adapters and harness for you. If you go to the bottom of his products page, you will see an order form to request a custom harness.
Brian truly embodies customer service and I will recommend him and his products to anyone!!!
