Popping noise in front left?
Laubage
I just noticed that there is a subtle popping noise from what seems like the front left of my truck. It happens more when I'm at full lock, backing up or making a turn.
Anyone notice something like this? I just installed an Icon stage 1 and light racing UCA's if that sheds light as to what it might be.
I've got that same issue right now and I can't seem to figure out what's wrong either.. I've installed new cv shafts, shocks, and sway bar links. I have a new set of ucas but I'm not going to install them unless I know they're the issue. If you find out what's wrong please let me know!!
Is the tire rubbing on the body mount or mud flap? Look for shiney spots on the paint/plastic.
What Antman said....he is a very smart man.....in addition to checking for the rubbing, how is the castor set? You want to get as close to +4.0 as possible, which will push your wheels forward. S if it is rubbing where Antman says it might be, this may be your fix.
Check all your wheel lugs and be sure none are loose!
So looking under my truck, there is no rubbing but it looks like the stabilizer bar is hitting the frame of the truck. Any way to fix this? I'll post pictures soon.
It's the bent part of the stabilizer bar (towards the middle of the bar. It's resting on one of two forward oriented support braces. The right side has plenty of clearance and the left side is touching the bent part of the stabilizer bar.
Purchase the sway bar relocation kit. It drops the bar and those support braces and should stop the two from colliding. I've seen them on eBay fairly cheap, any of the sponsors on here should sell them too. I ordered mine on sale from icon off their website think I paid around 30$ shipped.
I installed the sway bar relocation kit already included in my stage 1 suspension. It moved it forward and down. It helped it not rub against the coilovers, but now it's hitting the front of the "compartment" bout to upload pics.
Alright, here is a shot from the drivers side looking into the area under the skid plate. You can see where the sway bar is touching the brace.
232323232%7Ffp%3B%3C9%3Enu%3D3239%3E%3B32%3E9%3A8%3EWSNRCG%3D35%3B9%3C4%3A593339nu0mrj
Another possible lead I found was... chipping on the drivers side UCA. Not sure what's causing it, but there's no rubbing and these chips seem fairly robust (to the point the finish is gone at those points).
232323232%7Ffp%3B93%3Enu%3D3239%3E%3B32%3E9%3A8%3EWSNRCG%3D35%3B9%3C4%3C577339nu0mrj
Welp, after browsing some. I saw harper7's post on this. I think I put the skid spacers in the wrong place. Doesn't looking like they're for the skids, but relocating that brace instead.
20120328_010251.jpg~original
Is it going to be a problem in the long run? Rusting... etc?
If your asking if you need to put the spacers on,then yes you need to put them on or take your sway bar off. It will bind more and possibly damage the sway bar mounts or link if you really flex the drivers side. It's not that hard to do.
Hey harper, I was referring to the chips on the UCA's. I found it weird that they were only on the drivers side UCA and not the passenger side. Thought maybe something was up.
I just installed the spacers and it gives me about a millimeter or less of clearance. Doesn't seem like much. Is that about right?
Not sure what's up with those chips . Mine didn't have any and I drove on plenty of gravel and rock roads before I took them off.
Seems like you should have more space then that but as long as they don't hit is what matters.Heading out the door....Happy Holidays!
