Post up your aftermarket power inverter pics
z28suka
I am trying to figure out where I am going to put my aftermarket power inverter and need some ideas. If you have an aftermarket power inverter in your 4th gen post up a pic of where you put it please.
Jon
there is one for sale from an FJ on the fj forum for $75 i wanted to buy it but have no idea how to hook it up
B&D 750 watt hardwired to the deep cycle bluetop Optima under the hood with 2 ga wire connecting it all.
Also have a 300 watt hardwired under the passenger seat.
Very nice. What are those two D batteries for mounted on the rear near the inverter? More pictures please!
I don't really see anything that looks like d cells unless you are talking the two additional 12V outlets mounted low and left of the inverter.
These aren't the latest pics but they show the dual batt setup. Using a Surepower isolator. Works perfect since I installed it last April.
Sorry, my mistake they looked like batteries at first. Where did you get the tray for the secondary battery? Was it a custom fab or can you buy a kit?
WOW! Thats is completely AMAZING! I agree with the other guy, thats the best ive ever seen! Did you do this yourself?
I like your setup....I built a tool box in the back of my '89 and never thought about turning it into a bed. What brand of fridge is that?
Jon
Is that really 2 gauge wire?
It looks more like 4 gauge but I may be wrong, hard to tell in pictures vs in person. The wire just doesn't look big enough for 2 gauge, nice work though, I really like that setup!!!
Under the hood (between the two batts and isolator) is 4 ga wire. From the Optima all the way to the back is 2 ga (because of the loss at that distance). It is on a circuit breaker and everything is fused.
I have run the fridge nonstop since last March. Even in the summer, including two weeks in Florida last July, I could go 2 - 3 days without the fridge automatically cutting off from the preset minimum. Not shown in the pics is a digital volt gauge that replaces the less-informative green, yellow, red, one that is in the pic.
That makes sense about the wiring.
You did a really good job, I saw your pics on the hunting post also.
Someone earlier asked about the 2nd battery tray, what did you do for it fab, purchased, etc. My old Tahoe ran 2 batteries and I wouldn't mind doing the same with the Toyota, especially when I am in the woods messing around.
The battery tray wasn't hard or expensive. I bought a universal mount at Pep Boys and drilled four holes in my wheelwell and used four blue loctited nut/bolt combos. Touched up the four drilled holes with touchup paint then siliconed them. Had to use spacers and a couple washers to make it as even as I could. It fits in there pretty good. Nothing I'd do different with that.
I would, instead of saving a few bucks soldering lugs and adding the loom to Lowe's purchased wires, just buy some welding cables made to what I needed. My cables are made pretty good but it took a lot of time.
I'm sure you're sick of hearing this by now but wow...! That is amazing!
What a dream set up you have there, reading the specs of your truck it's a dream 4R overall.
Nicely done!
Really appreciate the comments. I want to do a build thread and show all the survival preps I have inside, the subfloor stored recovery gear, and the modular setup that allows me to add/remove things (table next to sleeper that isn't shown, jump seat that still fits in there, etc.
Mid-April I'll do a thorough writeup.
