Post your LIFTED pix here!
i'm back
:rapture:
just a cheapo daystar 2.5/1.5 lift with 275/70/17 K02s mounted on black FN FX pro wheels.
love it
oh there are 4 tires/wheels in the back which is why it appears raked. with no load in the back, the back sits slightly higher.
love it
That looks really mean! Do you have any rubbing at all with this setup? I'd read that 275's should be fine with a slight lift but wanted to confirm prior to biting the bullet.
Copy a lift?
I found a 4runner parked that I want to copy their lift but don't know what they used... Running 285/70/17s, both wheel wells sit 39" from ground with 7" of room from tire to well front & back. My SR5 sits 36 in back, 34 in front with 6.5 & 4.5" from tire to well respectively (with 265/70/17s). Does anyone know if that would be a 3/2 leveling kit that would make that change?
Looks good Bocean. Do you happen to have center hub to fender measurements?
[MENTION=142164]shrub1[/MENTION] sorry for the delay as I've been traveling all month. Here are my measurements:
Front - 23.75"
Rear - 24.75"
Hi how's it? Just wondering are you able to reinstall back your radiator support?
[MENTION=154140]Got2bpro[/MENTION] Loving the suspension. Better ride quality and appearance compared to stock. The radiator support is reinstalled but had to add washers to prevent it from rubbing the sway bar.
2015 sr5 premium
so i bought my sr5 p back in November of 2014 and i have 65k on it already!
figured i post some pics of the transformation..
pretty standard build but i think it looks pretty clean...
some more of the same
my bull bar was stolen awhile back and i actually like it better off so i guess its not that bad...
the blackout grill is the last thing i have done...
i really like it!
i wanted to make the front end look like a big hole and or snake fangs haha
i also added the blackout emblem overlays...
will take a more updated pic soon
Front - 23.75"
Rear - 24.75"
No worries. Thank you.
TRD Pro Suspension
[MENTION=165738]Bocean121[/MENTION]
Hey no worries. Thanks for getting back to me. I ended up picking up a set from another member. Thanks though!
Front - Bilstein 6112 - driver side at 6th notch, passenger side at 5th notch
Rear - Bilstein 5160 w/ Wheeler's T13 Spring
Swapped shoes out. Now running 17x8.5 SCS SR8s with 34x11.5(285/75) Nitto Ridge Grapplers. Build thread in my sig
