Power Antenna Toggle Switch
jaredking733
Hey all,
If you have a power antenna (that still works) and don't like the constant up and down that it seems to do constantly, you need to do this mod! I first read about it here, but figured it would be a huge PITA so I put off doing it until last night.
I went to Advance Auto and bought a roll of 18ga wire, a small pack of butt connectors, and a toggle switch.
I pulled the center trim piece from around the radio and removed the 4 screws holding the radio (mine is aftermarket) in. The radio came right out.
I searched the wiring harness for what wire I thought might be the power antenna when I noticed it's plainly marked, which made this job super easy.
I clipped the wire, stripped both ends and added butt connectors.
Then, I mocked up how I was going to run the wires, which was right out of the back of the console, under the carpet, behind the fuse panel cover, and over to the big dash knock out.
After cutting roughly 4' of wire, I stripped the ends and connected them to the butt connectors on the wiring harness. I then turned on the key to make certain I had the right wires cut. No antenna movement. Touched the wires together and the antenna went up. Separated the wires, it went back down.
Perfect.
Reinstalled the radio and trim, hid the wire under the carpet and interior trim, and used two more butt connectors between the switch and new wires.
After checking the switch for proper operation, I used s stepper bit to drill a 9/16" hole in the knock out. Tightened down the little bolt on the outside of the switch, straightened the on/off switch, and popped back in the knock out.
Voila!
Now, when the switch is turned on, the antenna comes up and stays up. Off goes back down and stays down.
Coated the antenna in some WD40 since it probably won't see much usage any time soon since I pretty much only listen to podcasts and I iheart.
Hope this helps somebody! It was much easier than I was expecting!
Picture of the switch
on the list! The fact that my antenna would be up even if im using the aux setting is annoying as hell....
Yeah, it drove me crazy too.
The thing that really annoyed me was when i turned the truck off, but kept it on accessory to keep the radio going while getting gas for example. When I started the truck, the antenna would cycle every time. Annoyed the crap out of me.
But, this whole job took only about 45 minutes not including the run to Advance, and I was really jumping in blind.
If you get bored, do it! I can't tell you how nice it is to only have it go up when you want, which is rare for me.
I must do this! I have an aftermarket head unit with all the attachments, Bluetooth, backup camera, etc. - every time I use anything, including simply reversing (the screen turns on, goes to camera view), the antenna comes up.
Super annoying.
This sounds like the fix I was looking for. Glad I searched here first. Thanks for posting!
Good idea. I just finished my stereo and rarely listen to radio. My sub amp and antenna run off the same power from stereo so my be a little tricky to turn on amp but put antenna to switch I'll have to investigate
I don't need it. My Alpine only calls the antenna when set to TUNER. I don't know why all HU's aren't like that.
Agreed. I have the Pioneer AVH-X4700BS and honestly love it, but the "bs" should refer to this antenna nonsense.
It is indeed a useful mod. Here's mine. My intent was to use it when wheeling in terrain where it (or a whip) may otherwise be damaged. This way you have full antenna control and can still use the radio with antenna down. I use the "Y" adapter so I can run both rear glass antenna + power antenna. Turns out that in most cases I have found the rear antenna to be adequate and do not even need to raise the power antenna...
Space is tight where I put the switch - I had to bend the terminals to get everything to fit. I scribed the cutout with calipers, and then cut the plastic cleanly by heating an exacto blade with a torch. Cut a little at a time until it was done, and then cleaned up with a small needle file.
This is the small rocker switch I used: http://www.amazon.com/gp/product/B008TOXEYS
If anyone needs it, I'd be happy to post more pictures. Don't hesitate to ask.
Everything is still working great and I think I've only used the antenna a handful of times. Nice to save all that wear and tear on the motor.
Yes please, and thank you!
I did this some time ago. My JVC HU keeps the antenna up if it's on. My concern is when I'm on a trail I don't want the damn thing getting destroyed. I have no interest in the Taco whip being I listen to a lot of AM sports radio. Very cheap and easy mod. Cheers -
