Problem with mirror turn signal and puddle lights
Crseth
Bought my wife a used 2011 SR5 and the turn signals and the puddle lights in the mirrors are not working. Has anyone had this problem? I'll check the fuses when I get off work this evening, just wondering if this is common?
Just checked all the fuses and they are fine. The blinkers in the mirrors are working guess I just didn't see them last night. Do all SR5s have the puddle lights hooked upor is that a limited option? It has the lights in the bottom of the mirror.
Its standard on the SR5's and LE's.
The turn signals can only be seen from certain angles- I guess you figured that out already though!
The puddle lamps are incandescent bulbs so it's possible they are burnt out (doubtful), but they are an adjustable option via the Techstream software. You can program the amount of time they stay on after you unlock the truck, and I'm pretty sure you can turn them off too. Have the dealer check that out for ya.
Good luck!
I too have a 2011 and both of my puddle lights stopped working ... doubt they both burnt out at the same time with only 40K miles. Did you ever figure out why they weren't working?
REE
