Project Stormtrooper (01 SC build)
Just curious what are the lift sleeves you have on your rig?
They are sleeves you install at the bottom of the coil at the shock instead of a top spacer. Steve at SS used to make these for his front ome lifts to achieve 3" without causing excessive droop.
Got my Icons put on yesterday. Took more time to adjust them than the install. Still working on getting them dialed in.
Old vs new
Just need a set of Icon upper control arms now.
I'm going from Toytec Boss coils to the 5100s because they didn't last that long.. I'd imagine the larger rod diameter of the Icons would allow them to take more of a beating / last longer than your average shock?
I have read a few things about the Toytec Boss colors not lasting. These size of the rod and the shock body look heavy duty. Pictures don't do justice how beefy these 2.5's look.
Definitely let us know how the ride compares to your old setup! If I have bad luck with the Tundra 5100s, this is the front setup that I plan to go with once I have the funds.
