While reading on the 3rd gen Tacoma forums, someone mentioned Toyota added an electric auxiliary heater (PTC heater) near the heater core to help with heat in the cabin when the motor isn't warmed up yet. I'd had this in the past on a diesel VW (and heard about it in other diesels) but haven't heard about it in many gas powered vehicles (because they usually warm up much quicker).
Being curious, I went and looked through the parts diagram and it appears as though we all have this already installed as well. Not sure if the same conditions need to be met, but I'd imagine they are close:
-Engine running
-blower fan "on"
-Temp set to max hot
-Engine coolant 65F or lower
-Outside temp 50F or lower
If these conditions are met, an electric heating element fires up to help heat the air coming out the vents. It won't be hot, but should at least be warmer than ambient air temps until the coolant comes up to temp to take over.
I didn't see it mentioned in the owners manual or here prior, so here you are.
-Engine running
-blower fan "on"
