jca21
Considering throwing in a spacer to level the front out and run 275/70/17s rather than the 265/70/17s.
Question for those of you with spacers on trail editions.
Did you have to adjust the kdss after installing the spacer?
Also, did you need to do the yaw rate and acceleration sensor zero calibration.?
How much mpg/kmL do you think i'd lose by running the 275s vs the 265s?
my original understanding was that spacers do not change the suspension geometry and maintains original ride quality thus does not require the kdss being adjusted or the zero calibration on sensors.
thanks folks.
also, there is debate on which spacers to order. Could you recommend the correct spacer to level out the truck? i'd preferably like to order from toytec.
thanks folks.
