Quick t-case fluid confusion
amalik
Senior Member
Hey guys,
The owners manual calls for 75W-90 GL-5 gear oil in the T-case. Simple enough right?
Well, with the weather below 0F (And in Colorado, that happens some months) -- the manual calls for 80W-90 in the Front and Rear differentials.
So is it suddenly OK to have 75W-90 in the transfer case with 0 below or should/can the 80W-90 go in there as well? I would think if it's weather related, 80W-90 would be recommended for the transfer case as well.
Thanks for clarifying.
I would think the 75w-90 is for colder temps. When it warms up it should be the same viscosity as 80w-90 which would be for more moderate temps.
The manual does say ' except add' when it recommends 80w... we have automatic differential disconnection from my understanding, so maybe im misreading it and it should be 75w in all 3...
Toyota likes 90 or 80W-90 for diffs, except ADD diffs in which they want 75W-90.
Toyota likes 75W-90 for trans and TFR; in reality almost any oil, including motor oil, could go in the TFR.
Diffs need GL-5, no exceptions.
Toyota says GL-4 or GL-5 for the Trans, the community says use GL-4.
In the USA marketplace, 90 or 80W-90 generally means conventional dino-type oil, and 75W-90 generally means syn.
I put Mobil 1 75-90 in all three after drain, refill, drive, drain, refill. Everything I read and everyone I spoke to said 'meh, no difference,' so I used the same to keep it simple. But don't follow my example because I ignorant.
I think Pluton's correct about the synth 75-90 vs dino weight 80-90 designation because I recall being told the same thing, which may be another reason I decided mobil 1 synth 75-90 is fine across the board.
