OK, here are the pictures for the fix, sorry I took so long.
This first picture is of the general area. Note that this fix needs to be done to both sides of the vehicle. And even though the sounds you might here sound like they are coming from somewhere else (much like mine did) this is actually where they are originating.
This issue still present? lol
Dont know off its a little late but I had the issue myself but fixed it by unclipping the black plastic pieces on each side of the sunroof. They are at the front of the sunroof on each side with a black "accordion" like material attached to it. As soon as I unclipped those pieces but left them sitting there not clipped in, the sound went away.
If its an issue everyone is still having, I can upload some pictures on it to show what im talking about.
Just as an update to this, I was having a gnarly sunroof rattle and found it would go away if I pushed up on the glass. Decided to try putting tape on the body around the back side of the glass and found that 3M Super 33+ electrical tape works great. I cleaned the sheet metal with denatured alcohol and stuck a couple layers of tape on and no more rattles. I think what happens is over time the seal gets old, dry and shrinks from constantly being in the elements. Combine that with the hinges that get loose over time and you have a rattling sunroof. Sucks we can't just put a new seal on but the tape works. Black electrical tape certainly looks better than the white medical tape someone used earlier in the thread LOL Now to fix the rest of the rattles in the rear passenger area :ybrick:
I'm curious about your experience dropping the headliner...what it a huge pain in the rear?
I don't think it was a PITA, say, compared to dropping the Tcase :bounce: Admittedly, I practiced in the junk yard when I pulled the sunroof cassette so I was more confident and took a lot of pics.
This next picture shows a close-up of the problem area. Note the round bar that runs down this channel. This bar controls the movement of the wind deflector. So it moves forward and backward down this channel. The reason I believe that some people are having this rattling problem and others are not is due to the fact that if the sunroof is not adjusted just perfectly, than this bar has some load on it, which causes it to flex slightly bringing it closer to the channel edge.
I have the same “loose glass” sound when closed. Here is a video I made to show how much play I have in the closed position:
SunRoof
Gonna try the tape fix.
73
