shootmymime
I'll get some pictures up tonight of the finished product.
waiting-Waiting-WAITING :director:
Those arms are bad Ass bro. Now are you making adjustable ones or ? Lets say a person has 3-5" rear lift.
Round vs Square, Looking good man! I reused the stock barrels on the axle end since i used OEM bushings, did your poly setup require new barrels? I think i want to swap to Poly at the axle.
How close are your welds to the outer edge of the barrels? I was TIGing so i had to be careful with the heat it was so close on the sides. What tube did you decide on in the end?
Adjustablility is going to be your selling point and why most people will buy them. While there are failures that have happened, for 98% of us we don't need these because we bent our old ones, but because we need to adjust for our lift kits and what not. At least thats why I want them...
I vote for hems. I am not sure why people think the "Johnny" style joints are for some reason better? Rebuildible isn't always a good thing which C-clips and come out and things like that. Think of what off road sport puts the most abuse on joints, baja hands down. You never see Johnny style joints on any Trophy trucks. We see uni-balls and hiem joints. There is a reason, they are strong as hell, they are adjusted very quickly and easily, and replacement is very easy. I vote adjustable heims all day long!!!
You're correct, but the difference is off-road vs on road. Heims are hands down the best for off-road and for people that don't care about vibrations. The Flex Joints, Johnny Joints, and Duroflex Joints are better for on-road and have far less vibrations. I'll most likely end up doing a couple different options. Something more basic like heims, and a higher end like Flex Joints as well.
I wager the majority of any adjustability that is truly functional comes from adjustable uppers.
You cant lengthen the lower unless you want to reconstruct the back of the fenderwell and you are then lengthening the uppers also to keep things copasetic. Shortening the lower link to compensate for pinion angle seems like the wrong way of doing things to me. Adjustable uppers make kicking the pinion up a better option in my book and you have less headache keeping the wheel centered, saving you from munching on the front of the fender where your door doesnt allow for much trimming or getting into your rear bumper and body.
You are absolutely correct. I did a poor job of explsining. I would love to see a hiem on one side for adjustment and a fixed poly/flex joint on the other. You end up with vib reduction while still being adjustable.
You are correct that most of the adjustment needs to be in the uppers, but I know for certain some adjustment on the lowers can be benificial. No two cars are identical, so having the option to make small adjustments is a good thing. If it added extra cost or made the arms weaker to use an adjustable rod end I would be inclined to agree it's not worth the risk. But if it costs less, is easier to fab, and allows you to have the option I don't see the problem.
[MENTION=88391]NateMob[/MENTION]
On that note. The new Flex Joints from Summit no longer use c-clips.
Mine used full snap rings, not really c-clips. What about yours?
No problem man, I just thought this thread needed that clarification. You are obviously a bit more savvy and experienced with things like this than a lot here. You are definitely right on about small tweaks and no two rigs being the same. I know you've got the skills and means to build your own, when are you going to get started so we can see your setup with heims? :bigok:
ok i want a set... id like the hybrid version with adjustable up top... subing to this for updates.
