rear end sag on 95' v6
lh4runner
I have an 95' with v6 with 32'' tires and 193000 miles and have the famous rear end sag.
Is here a way to fix this or a cheep way to fix it?
Yes, unless you want the rear higher than stock (when it was new).
Or you could get a mild (2") lift suspension from Old Man Emu and the truck will sit a little higher than stock, and ride and handle better than it did new.
With a 2" lift, do you raise the front too, or are you talking about a raked stance for better handling? I was considering a minor lift in the rear.
I'm refering to a complete suspension lift, F+R.
You'd fix the rear end sag and gain 2", plus 2" in the front.
The OME (not OEM) lifts are the best there is for ride and handling.
