Rear Engine Seal Leak at 23k! May Not Be Warrantied?!
the owners manual has procedures for driving through water, so OP probably would have had a good case if they wanted to get an attorney since that can hardly be considered "unreasonable use" with respect to 15 USC §2304(c) since the owners manual discusses it
I agree completely. There's several examples of instruction for driving offroad in the manual, not the least of which is actuating 4lo for lubrication purposes at an interval. And some warnings about features and functions that should not be used on road.
Seems like toyota's warranty claim blitz should be their issue, and not the consumer that consciously purchased a toyota for reliability and quality service. I reasonably assume damage and repair costs every time I go offroad, but an engine seal at 23K miles is their issue.
Question for Toyota/Dealer employees - Are dealers required by Toyota to save failed parts for warranty claim for X amount of days for potential investigation?
*I realize this repair was done outside of warranty, just wondering
Yes, they are required to save all parts after warranty repairs. Toyota will call back a random amount of parts for accountability purposes and inspection. After that they scrap the parts not requested back.
Wow. I am really sorry to hear all this. I wrote service for two Lexus dealers in Houston for several years. I’m quite familiar with the warranty process and agree with most that the warranty rates are usually pretty bad compared to CP rates.
Make sure you fill out the survey with the lowest scores possible. Yes, this will hurt your buddy service writer and his monthly bonus, but it will hurt the dealer more. Now, it’s been about 7 years or so since I was a service writer, so I don’t remember what having Toyota corporate will do regarding you receiving a survey or not.
You can also suggest they run this via the third option, “I” for Internal. This guarantees you won’t receive a survey, but the dealership eats the ticket. So maybe ask the GM of the dealership what th dollar amount is for a 0 survey and a 1 Star review on every platform you can think of since they are crooks. Best of luck to you.
Nothing valuable to add here other than what a crock of crap. If mud on a seal damaged them we're all in for a world of hurt!
Did you waive your right to sue by accepting the reduced cost of this repair?
Toyota's Own Website says
"Let’s keep pushing the limits. When the dirt calls, the TRD Pro Series brings the toughness you need to rule the off-road. 4Runner TRD Pro is built to claw through challenging terrain and help you explore those places not found on a map. And the Tacoma TRD Pro brings the action to even the coldest, most remote corners of the Earth. Each rig has got the same proven engineering that’s won races and fueled adventures all over the globe, so, yeah, they can handle your local trails. Let’s get dirty."
Another reason to buy a jeep next time around.
Toyota dealers are the pits. All brands bad, but they seem to be taking things to new levels.
don't think the OP has a TRD Pro.
This thread is infuriating…
Personally I would have never authorized the work. It all went downhill from there.
Maybe if the seal wasn’t compromised due to poor quality and workmanship there would be any mud or debris in it. The truck was used well within its marketed use case. I would have expected 0 out of pocket on this one and a loaner/rental.
First step for the dealer is to satisfy the customer. The next step is for Toyota to figure out why a rear engine seal is leaking at such a low mileage.
I would add to satisfy the customer within reason. As for why the rear engine seal or upper oil pan is leaking, that's easy it's more than likely an assembly issue, not much else can cause that.
I think all manufacturers are cracking down on warranty work. However, I’ve come to learn that we as an industry have brought that upon ourselves. But that’s better left for another time.
When it comes to determining what’s warranty and what’s not. Our warranty clerk stated “If you absolutely without a doubt cannot prove that the damage was caused by the aftermarket part or gross negligence just warranty the part, it’ll cost us more in legal fees.” Maybe is a CA thing :spy:
My buddy works for a Toyota dealer and he said Toyota will kick back recalls and campaigns performed by techs that aren’t certified to do so. Thus, most techs don’t wanna certify, so all they are given is CP work.
Certification is a valid issue, the other half of it is that Toyota constantly is screwing over technicians and dealers with warranty parts & labor. For example we do an H0C recall to replace the rear bumpers on a couple years of Tundras. They give us a whole giant kit, but no new push clips (which get loaded with dirt and often break), if you try to warranty the clips (probably $20 for all new clips) Warranty kicks back the claim. Labor on some jobs is barely straight time, so people find shortcuts galore and so when they get audited they get slammed for not doing it the way Toyota wants. With most mid to higher certification level technician's days being 60~80% recalls most days that means they're probably not breaking even on flat rate because of labor rates. Then there's Toyota getting more and more picky about shit, leaking shock due to "failed seal"? Toyota kicks back the claim and goes "how did the seal fail?" **** if I know, there's a metal ****ing cap on the shock, you pay me to replace it not cut it open and do an engineering analysis. How else does a shock leak if not for a failed seal!? So now I have to rewrite my story to be some bullshit to make them happy for barely any pay on that job. This is a constant issue, not to mention the codes they give us are like 30yrs old and haven't been updated so you have to convolute your story to fit their very janky T1 & T2 codes sometimes.
There is a LOT of reasons why warranty work is getting worse in the automotive industry and dealers are getting pickier about it, not just Toyota.
Was there ever an acceptable explanation of how this happened? I mean whats to prevent it from happening again if you were only driving under normal dirt road conditions.
Probably not, because there's very little chance it'd cause it to fail. If the vehicle was submerged enough to get mud/dirt into the bellhousing up to the rear main seal, you'd have other issues in the vehicle probably.
Parts for all warranty work and most recalls are held until they're not wanted basically. i.e. if we've done X Recall for a month or two usually Toyota has had enough failed parts sent back to have a sample size and tells us to toss stuff. If we replace something under warranty, the part is held until it is either called back and sent to Toyota or they tell us they don't want it.
[MENTION=139152]4runner_RN[/MENTION]
You did say the vehicle has never been submerged up to this point correct?
Did they ever provide pictures and/or evidence of this "proof of submerged condition" to you? I'm still calling BS on that and I would strongly push on the corporate side of things to get reimbursed if you've spent any money and/or push they cover the entire repair.
It would help this thread if the OP had some pictures of the under body posted.
If the underneath is all scratched up, with some dents and rust does that constitute "normal use" or is that considered abuse?
Isn't there a mediation process for these kind of situations?
I appreciate everyone's concern. It was just unforunate. I know im on the short end but im trying to finish up my last month of school and work has been too crazy. Fighting this would've just been too much stress.
The important thing I got the car back and it's driving as it should be.
Unfortunately, the OP's situation is exactly why dealers try this crap. They'll sometimes find someone who just doesn't want to deal with it. Puts profit in their pocket and on to the next.
It's the same thing with scammers, you try enough people, and someone will eventually send you $100 for your great uncle the "Prince" to send your inheritance. (not saying the OP got scammed, but same tactic, you try enough people, some will pay)
I dunno... OP sounds like a victim, but is acting somewhat guilty by both the lack of pics under the car and description of whether he did in fact submerge the rruck to some massive extent.
A clean pic on the outside doesn't mean there weren't some Instagram photoshoots crossing LA area rivers this spring, etc. Just giving that example because after Spring rain it seems everyone with a 4x4 goes out seeking eivers and creeks lol.
Also not understanding how someone has a $42k+ truck with $5-6k in mods and yet "has too much school loan stuff coming up" to fight a dealer for 1-2 days in court.
Just seems like withheld facts are clues here. I'd have ripped a dealers head off if they fed me the same BS, and taken them to court for sure just on principle, hence my feeling there's some secret admission of something pretty funky that went on whth this truck, like a serious (or multiple episodes) of having the transmission partly underwater.
Doesn't make me right, but I often am.
Either way glad the OP got a partial discount on repair.
This was my thoughts as well. Every bit of Toyota 4runner marketing material makes it sound borderline offroad indestructable, but take it into the dealership and your 4Runner quickly become a gentle flower...
I've had my transmission pretty close to fully submerged a few times. In my trail rigs I've had water over the hood many times. Never had a problem in any of them with that causing leaks in the seals. That's the point of seals. To keep liquids in/out. The engine rear main seal is no different from the seals in the axles that routinely are submerged in water. Or the transfer case output seals, etc. Occasionally you get a bad one. That's what warranty should cover.
erinobr2000
