Rear hatch hits garage door. What are you doing?
This is all a big nightmare with my wife's new Outback and it's power liftgate. While it can remember different heights, it also means she has to park in just the right spot. What could go wrong?!!
Lots of great ideas here!
I just unload before entering the garage. Luckily our house that is being built at the moment has 8' tall doors and high lift tracks. On a side note, my wife is wanting an S3 to replace her 1 series. How do you like it? I am hesitant with getting another german car as the BMW has started falling apart around 90k miles. She doesn't love the IS350 otherwise it would be a no brainer.
The S3 has been a good car so far. The only issue I have had was the Haldex pump going out and that was covered under warranty. It's a small car, but if it is replacing a 1 series then I am sure that's not a problem. My GF has a 335i that we are selling since getting the T4R so I can understand your hesitation on another German car. TBH, I think the Audi will be more reliable and cheaper to fix than the BMW. The 2.0T motor is solid and actually makes good power for being a 2 liter. My S3 with chip, intercooler, and intake pulls pretty hard on our 335i. The BMW's are more fun to drive though and make you feel more connected to the road than an Audi will. I say test drive one and see how you like it.
Padding the garage door
Like others, I put pipe insulation on the cross members of the door. I have an old swing out wood door that stops at about 6'-6" when open. I put pipe insulation, which is closed cell foam, on the board across the center and on the tension rod at the bottom of the door. No matter where I stop in the garage I can open the hatch against the foam padding.
The garage door barely clears the roof rack now that I have a 3" ICON lift. I added neoprene rubber strips over the steel cleats where the tension rod is raised at two points near the center of the bottom edge of the door. The rack rubs these points but it doesn't scratch. With the lift the rear hatch does not open as far as it did before the lift.
Easy fix, I used the pipe insulation for AC pipes (black stuff slit on one side from Home Depot) the wrapped it around the garage door fins.. Works a treat and its adhesive and requires no vehicle mods :-)
Frontrunner stratchits, one of many uses...
From another T4R/Audi household I must say nice choice of rides OP!
My GOBI ladder protects the tailgate when I pull in straight. Maybe an excuse to get a mod...
With a garage ceiling that tall it why did they not put in a taller garage door? I have 8' tall doors and zero issues.
I wish the original owner/builder would have. Makes no sense to me. Just like how they only installed one outlet in an oversized 3 car garage... SMH.
Funny to see this. I bought my T4R with some scratches on the tailgate that look to have come exactly from this in its last home.
9' doors here though. No problem on the rare occasion that the T4R actually goes inside there to get worked on. It's mainly the JK's home since it sits with no doors or windows or top for 7 months of the year. And that fits no issues with 3.5", 37's, and a firestik sticking up. And the other side is of course garbage cans, shop stuff, kids outdoor toys, bikes, quad and plow (during winter), etc.
Anyway, it's all about the door size. But I suppose what I would do is add padding to the contact area if possible. On the door of course. I wish the prior owner of mine had thought to do so.
Sent from my SM-G900V using Tapatalk
I put a length of foam pipe insulation over the small part of the garage door that the tailgate contacts and its been working great for 6 years. Before that, I had one of those pool noodles in the back that I would just stick up there between them when i opened it.
Lucky you if you have a 9 foot door. Most garages have an 8 foot ceiling, unless the garage is considerably lower than the house floor level. That leaves 8 feet to fit the header, a 4x12 spanning 16 feet or so over the opening. So most doors are 7 feet high at the opening and even less below the door if it swings up under the opening. Roll-up doors can rise up above and behind the door opening but not solid wood doors.
If you limit the lift or travel of the tailgate then it won't rise far enough to clear a 6 foot tall person. I have trouble with that when I open the tailgate under my garage door. It's high enough to be out of sight but low enough to smack you in the forehead when you walk into it. Ouch, that hurts!
:ballchain:
4Runner hits garage door
Pipe insulation , walla problem solved!
attachment.php
Just pad the part of the garage door that it may hit. You can also limit how high it opens with some kind of rope connected to one of the lower D rigs then to the hatch. But ideally that's what the power window is for in the back.
Edit: Looks like you got it.
Pool Floaties
I have a metal lip on the bottom of my garage door. I bought 3 or 4 pool floaties, spilt them long ways on one side and they clamped right on the lip. I drilled a few hole through the metal and used wire ties to strap in place. I did this over the summer so i'm hopeful if there is moisture they don't stick to the concrete this winter but since they are inside the door I think they will be ok.
AndiGarage
