Rear hatch pulling away help
Snackie
Member
Hello,
A few weeks my rear hatch switch pull handle had a issue and the handle seemed to have broke a bit where it wasn't as sturdy as before.
A week later, the entire garnish, pull assemble started to pull away from one of the push snaps underneath.
My question is, I'd like to order the parts before I go in there.
Do you think I Just need to plastic push pins that hold the assembly tight or do I need to order something else that they attached too?
For the handle, do you think I need to order the plastic handle box or is this just another hardware holding pin that may have broke?
Door still work, just when I pull on it, electronic handle underneath is not firm and the entire piece pulls away slightly on one side where the plastic push in is. It pushed back on but doesn't hold the next time.
Thanks for reading that entire thing with improperly terms and for any help.
Thank you!
the garnish and handle assembly is held by push pins and some bolts. I suspect the handle has broken from its holders and the bolts are no longer holding it in place, the clips probably just pulled out without the bolts keeping everything tight. I would order the entire handle assembly and garnish and some extra clips. that way you only need to open up the rear hatch trim once
there are a few videos on youtube showing what you need to replace the handle and garnish
https://www.youtube.com/watch?v=0AX0cmOBai4&t=439s
erinobr2000
