Rear Lower Shock Guard for King 2.5?
Has anyone else used the new King Shock guard? Is replacing the rod ends something that a King servicer should be able to do or do they need to be sent back to King? It's my DD and I can't really have prolonged down time.
replacing the rod end is a major *****, and there's a good chance you can destroy the shaft if the proper soft jaws aren't used.
The spherical bearing needs to be removed first, and then heat is used to burn off the red loctite. I needed a 4' breaker bar to twist it off, after a few heating cycles. The soft jaws have to hold the shaft unbelievably tight so that I could use a breaker bar this length.
If whoever services your shocks is confident that they can do the work, and they have done the rod ends before, go for it. I would say the rod end is the hardest part to replace on those shocks.
The next time I order shafts, I'm ordering them with rod ends attached from King.
Ok. Thank you for that beta. When it comes time to replace them I will seriously consider who I choose to do it.
Sent from my iPhone using Tapatalk Pro
I disagree on this opinion. I replaced my shock rods with the soft jaw tool from King. It was super EASY to do and I didn't even need a 4 foot breaker bar to do it. A 2 foot breaker bar at the most! It was also my first time doing it too! I used map gas to get the rod ends hot enough to twist the rod ends off. Took me 20 mins MAX for each end to do it. BTW I used a typical table vise to hold the soft jaw tool which held the shaft in place firmly in place. Any one can do this as long as you have the correct soft jaw tool, vise, red loctite, and snap ring pliers.
does anyone know if the BPF shock guard will work with the king shock guard? I currently have the king shock guard but deciding if I should get BPF or FJ toyman.
I spoke with BPF and based on the measurements he gave me it should fit so I bit the bullet and bought the skids just haven't had time to install them. I will report back on the outcome.
here is proof for those of you who are wondering if the BPF shock skids work with king shock guards
Here's how my King Shaft Guards looked after 1 run. The other side didnt break but was quite loose. Keep in mind, i made sure they were secure and free from contact with anything around it.
I would replace it if it wasn't so expensive. Looking to get the BPF's but wished they had slightly more coverage.
Shaft or Knuckle
Not the title to a terrible 70's porn.
You're going to need both, as there's not a product that cover both the knuckle and the shaft. My solution was a set of BPF protectors coupled with the following:
Boots!
couple seconds with a pair of scissors to cut out a quarter inch section down the middle so the back is just slightly open (let's mud n water out), couple snips here 'n there to cover the knuckle, couple of zip ties (tight around the shock, loose mid and low) and you're covered, both flexible and solid... which can be said about a lot of things in life... but seriously.. shock boots!
Well Rago is a no-go. They won’t modify their current design. When I get some time I reach out to some more fabricating places to see if a design can be worked out.
I wonder if I could convince RCI to fab something since they are local and already have offerings for the 4Runner.
Shock Boots
I have been more than completely pleased with the simple fix of shock boots to protect the shaft. Slice down the back to let it breath so mud and water doesn’t collect and it is good to go.
See if a local welder can sand down the powder coat and weld on a small extension?
