Rear pinion bearing replacement kit?
thebrandon
I've having a little trouble locating a kit with everything I need to replace the rear pinion bearings. I need to replace one or more of the bearings back there and if I can get it all in one place I would like to do that rather than paying for individual parts. Anyone know of a kit that has what I need?
Thank you.
Since you're having trouble locating an all-inclusive kit, I assume you have little experience setting up differential gears.
My advice would be to take it to a shop that does have experience setting up differential gears.
Achieving the correct contact pattern between the ring and pinion, can be very difficult and time consuming without the proper tools, and experience.
I agree that you should take it to a pro. But if what to F up here you go: www.just-differentials.com. These guys will also fix your diff after you "f" it up.
Lol!
I've ripped apart a few axles. My buddy that works for Toyota would be doing the reassemble ;). Your link also doesn't work [MENTION=107180]runner823[/MENTION]. I'll just be piecing together my own "kit" I guess.
if your buddy works for toyota why do you just have him get you the parts at his cost...? he should be able to look up everything needed to do the job. im just in the middle of my regear, i can just give you my old bearings if you want to go that way, they are perfectly fine, and have a good wear pattern then all you would need is a new oil seal, oil retention baffle and maybe a couple of shims. i also have a brand new crush sleave for it if you want...
Are we talking about a master install kit for a differential? Last I checked, they came with both pinion bearings and carrier bearings, crush sleeve, ring gear bolts, pinion seal and lock nut for the drive shaft flange. What else would you need that you'd have to piece one together?
