Rear Sway Bar Question
Hadelson
Current T4R is 2014 Trail-Non KDSS. 90% Road-10% off the road. Has 19MM rear sway bar. Looking at a Whiteline 24 MM bar as direct conversion. Anyone have experience on this? Will I need extended/Reinforced End Links and most important, does it fit?
The bar on the 2014 and set-up is identical to the one on my old 2005 T4R. Whiteline Web Site only notes bar fits up to year 2012.
I can't find the sway bar on their website. Can you provide a direct link to te sway bar on their site?
You'll most likely reuse the stock end links. I've actually been running without my rear sway bar for the past month or so and just got around to putting back on my end links. I didn't notice the difference.
why? beef up the suspension and pull the bar off, the extra travel is sweet and you get used to the extra movement in the corners pretty quickly
